white balance pick in FL not working at DVinfo.net
CineForm Software Showcase
Old August 6th, 2010, 06:17 AM   #1
We have run into a gamestopper with the whitebalance pick in FL. The beta and now the newest version (Neo4Kv507b267-100803) are not functioning correctly in our Win7 x64 workstations. When loading FL, and then trying to set whitebalance, the pick tool will apparently load, but then when clicking on the video, deselects FL, and often crashesFL or the program simply stops working.
Is anyone else able to reproduce this? Watch the bar on the top of the FL window, then try to whitebalance with the pick tool. The program bar loses focus normally as though the pick tool worked, but the WB does not complete and it locks up or sometimes crashes.
Two of the ws are using nVidia 8800 GTS cards. One has CS3 and one has both CS4 and CS5. We haven't tried our third ws with a different gpu, but will soon.
UPDATE: We dropped back to version Neo4Kv506b265-100712_1 (from July 11) and it worked perfectly on two of our ws, so it is a bug or something apparently got turned off, or connected incorrectly in programming.
http://lightinaction.org
"All in the view of the LION"
Stephen Armour is offline   Reply
