1440 x 540? at DVinfo.net
CineForm Software Showcase
Old June 28th, 2010, 02:29 PM   #1
1440 x 540?
Using the latest version of Neo 4K:
When exporting as a CF avi my framesize is 1440 x 540.
Should be 1440x1080.
Aspect ratio = 2.667 and not 1.33
Anyone else having this problem too?
Went back to Prospect latest version, made a movie and all was ok...
Gildo Houtekamer is offline   Reply With Quote
Old June 28th, 2010, 06:49 PM   #2
Hmmm...
1440x540 looks like a single interlace field (from a 1440x1080 60i source)
Maybe double check all of your HDLink preference settings.
Was the source footage HDV 60i ??
Bob
Old June 29th, 2010, 04:17 AM   #3
Source footage was hdv 50i
HD Link was set as usual: 'high quality' and automatic.
Old June 29th, 2010, 12:12 PM   #4
You might try using the HD Link manual settings for interlace and frame size and see what you get.
I do recall having the same problem once before (on earlier version of PHD), and I believe, in my case anyway, the manual settings corrected it.
Bob
Old June 30th, 2010, 06:14 AM   #5
Tried it, several times, but didn't work.
Still comes out as 1440x540...
Back again to Prospect, but now my clips have no audio in the last second.
Captured with hdvsplit, sound is ok, converted with HD link to Cineform Avi's, sound is gone in the last second...
Also not apparent in any mediaplayer, so it's not from Pro Cs3 audio conforming...
After testing on a laptop: Same problem: No audio in last second
[Capturing through hdv split and converting to Cineform Avi with HD Link]
Last edited by Gildo Houtekamer; June 30th, 2010 at 09:55 AM. Reason: additional info
Old June 30th, 2010, 06:06 PM   #6
Pretty strange...
Probably best to submit a trouble ticket to Cineform.
Bob
Old July 1st, 2010, 08:33 AM   #7
Thanks for your help.
I am going to finish my project first, with Prospect installed, work around the the nasty sound endings and than format my drive.
If that's not working I will submit a trouble ticket...
