MC5: Imported Cineform avi's come in as two split clips at DVinfo.net
CineForm Software Showcase
Old June 12th, 2010, 12:13 PM   #1
Hello,
I just installed avid media composer 5.
Using AMA to link to the cineform .avi files that I have, the files come in very quickly. However, when I view the clips, the one clip becomes two in one clip. Kinda like a split screen effect. Plays fine just looks wrong.
Any one else having these problems?
And yes I did submit a ticket to cineform.
Simon
Simon Zimmer is offline   Reply With Quote
Old June 12th, 2010, 10:58 PM   #2
couple of things you can try:
1. reinstall the cineform codec
2. you dont mention the version of cineform you are using but i have heard issues like this also gets fixed with messing around with the 3d eye settings.
iam having a different issue though...my imported clips show as 4x3 aspect ratio when it should be 16x9 and also , playback is not smooth
Anish Sharma is offline   Reply With Quote
Old June 13th, 2010, 07:43 PM   #3
Neo4k
Good point!
I am using Neo4k. I did try reinstalling cineform. Actually, due to some other problems with MC5, I reinstalled my whole computer to get a clean start with MC5. Everything works great now except for the cineform AMA imports.
I guess there are still a few bugs they have to get out. I wrote a support ticket on Saturday.
Later,
Simon
Old June 14th, 2010, 05:35 PM   #4
Simon, we've seen this here too and are looking into it. I think this is "common" behavior right now. Give us a day or two for more insight....
David Taylor is offline   Reply With Quote
Old June 15th, 2010, 06:48 AM   #5
No problem.
Jake told me the same.
Thanks for the quick response.
Otherwise, once it is fixed, Avid is going to be amazing to use!
Simon
Old June 16th, 2010, 12:36 PM   #6
Hi Simon, we have a new build posted that fixes the MC problem. Please give it a try and confirm that it works as you expect. CineForm Product Downloads
Old June 16th, 2010, 06:06 PM   #7
Hi David,
Thanks for the message.
Yes, I just updated cineform. The good news is yes the import has fixed the split clip issue however now I am having problems playing back the audio. It is distorted and seems to get stuck in a loop.
If I play the cineform file in windows media player, the audio plays fine.
I do have AC3 filter installed. I even did a fresh convert with HDlink onan AVCHD clip to cineform.
I am using Neo4k with the latest build.
Should I write another support ticket?
I will also see if anyone on the avid forum can help me out.
Simon
Old June 16th, 2010, 06:16 PM   #8
David Newman says he thinks the audio is probably an Avid problem as CineForm is not processing the audio. You might see what they say on the Avid forum....
Old June 16th, 2010, 06:20 PM   #9
CTO, CineForm Inc.
Yes, we have little to nothing to do with audio playback in Avid. Avid is reading the file, QT/Avid is demuxing the file, QT via our codec is decoding the picture, audio is handed off to Avid -- we don't get to touch it (even if we would like.)
Old June 16th, 2010, 06:22 PM   #10
Hello,
Wow! That was a quick response. Thanks to you both. :)
Okay, I will let Avid know.
Video looks great though.
Thanks for the support!
Simon
Old June 18th, 2010, 08:05 AM   #11
Cineform and Avid:
It works now David^2.
Great product!
Simon
Old June 18th, 2010, 08:24 PM   #12
Seeing same kind of thing
I'm seeing something like this in FCP. It seems like the screen is shifted over about 25% and the part that is cut off spills over to the other side. I just installed NeoHD yesterday (upgraded from Neo Scene) and I believe that I have the latest build. Should I uninstall completely and reinstall (does the upgrade to NeoHD perhaps not install the codec again?)
Jason Rosenfeld is offline   Reply With Quote
Old June 18th, 2010, 08:38 PM   #13
CTO, CineForm Inc.
That was a failure of the previous version, make sure you have v5.0.4.
Old June 18th, 2010, 08:57 PM   #14
Thanks for the prompt reply. Makes me not feel as bad to be editing on a Friday night. :)
Looks like I have 5.0.8.132
When I check Cineform under system prefs, I see 5.0.8.134
Is the answer to uninstall neoscene and then do a new install of NeoHD?
Old June 18th, 2010, 09:18 PM   #15
CTO, CineForm Inc.
That is a Mac version number. The failure was on the PC only, and not related to the Mac. As I haven't heard of any Mac issues in MC5, please file a trouble ticket.
