NeoHD/4K/3D v5.0 public betas now available - Page 5 at DVinfo.net
CineForm Software Showcase
Old May 9th, 2010, 07:54 PM   #61
I just snagged the trial version... as long as there's no limitations to it, I should be fine.
Marty Baggen is offline   Reply With Quote
Old May 9th, 2010, 07:54 PM   #62
Have you viewed your output with VirtualDub? If all viewers look the same, it's probably not a conflict with Media Player. Good to discount that one first.
http://lightinaction.org
"All in the view of the LION"
Stephen Armour is offline   Reply With Quote
Old May 9th, 2010, 07:57 PM   #63
Only have WM and VLC which doesnt play CFHD files.
But again if I come back to using Neo 4.3 and windows media the line isnt there?
I'll download VD now then
EDIT
Yes the line is there in VD.
David Dwyer is offline   Reply With Quote
Old May 9th, 2010, 08:05 PM   #64
EDIT
Narrowing down. Better post it again as a possible bug and give your whole setup workflow so others with similar setups can test it. Need to squash that one if it's there for sure!
Old May 9th, 2010, 08:06 PM   #65
David... my system didn't like your project file. Can you give me the settings of your project and sequence, and output settings as well.
Old May 9th, 2010, 08:09 PM   #66
Odd its just a CS4 project file but I was using the Cineform Preset:
General
Editing mode: CineForm
Timebase: 25.00fps
Video Settings
Frame size: 1440h 1080v (1.3333)
Frame rate: 25.00 frames/second
Pixel Aspect Ratio: HD Anamorphic 1080 (1.333)
Fields: Upper Field First
Audio Settings
Sample rate: 48000 samples/second
Default Sequence
Total video tracks: 3
Master track type: Stereo
Mono tracks: 0
Stereo tracks: 3
5.1 tracks: 0
Submix mono tracks: 0
Submix stereo tracks: 0
Submix 5.1 tracks: 0
Exporting to CF AVI
1440*1080
1.33 PAR
25fps PAL
Upper Field
Old May 9th, 2010, 08:15 PM   #67
CTO, CineForm Inc.
David, please work with support, as you have a number of outstanding issues (with this very footage) that others can't reproduce -- this thread is not the place for detailed support. However can report, I have tested this using the same footage (yours), and it does not do it here. I have tried many combinations, max quality on/off, 1920x1080 vs 1440x1080, 3D and 2D exports. Do check you export settings, as maybe the preset is wrong for 1440x1080@50i. I'm running a Premiere beta release, one version earlier than yours (don't expect that this is the cause) but I'm getting an Premiere crash when selecting "Match Sequence Settings", this is not pointing to our code (rather a Premiere error "[..\..\Src\CompilerMixer.cpp-66]"), so it either means I need the release CS5 or the preset is odd. Manually setting the parameters for the export works fine.
Old May 9th, 2010, 08:17 PM   #68
David..... as per your settings and with your footage, I am unable to replicate the frame shift.
My output is clean.
If it were me, I would recapture. That's the first link in the chain. I know you get a clean output with the previous Cineform version, but it's a quick task and it may be the gremlin we're looking for.
If not.. then indeed, it may be a bug of some sort.
Old May 9th, 2010, 08:22 PM   #69
My output is clean.
Thanks Marty, Its odd but as its 3:20AM here the recapture will have to wait till later - Off to bed now
I have CS4 full and CS5 Trial installed on this PC.
If is the source footage I'll go mad - Thanks all
Old May 9th, 2010, 10:00 PM   #70
OK, I did a dopey thing...
Didn't read this thread before I installed NeoHD 5 beta over my existing NeoHD. So I didn't realize (remember) that I needed to uninstall 4. However, I did a "request activation" for 5 and and received an activation key, but it doesn't work. Don't exactly know why - I guess the key is good for v4 only?
What do I do now? Just wait til v5 becomes final and then request activation again? Or do I have to uninstall version 4? Ack!!!
Follow me on Facebook!
http://www.facebook.com/TCPalmSherriNestico
Sherri Nestico is offline   Reply With Quote
Old May 9th, 2010, 10:10 PM   #71
CTO, CineForm Inc.
Not too dopey. You can't activate yet as this is beta, we will enough e-commerce for doing upgrade last this week. The recommendation for un-installing is unrelated to activation, it just means we know you have a clean install when new components are added.
Old May 11th, 2010, 12:46 PM   #72
What is the interpolation curve between keyframes in NeoHD First Light?
Ed B
Edwin Baldwin is offline   Reply With Quote
Old May 11th, 2010, 01:01 PM   #73
CTO, CineForm Inc.
Edwin, Linear interpolation for now.
Old May 11th, 2010, 01:18 PM   #74
David, the NEO4K 5.0 beta works well, but FL is still interpreting 30 fps I-frame only video as 24fps.
Will that little fix make it into the Friday release?
BTW, congrads on the new tools and other things in FL! Really great stuff and very welcome.
Old May 11th, 2010, 01:41 PM   #75
CTO, CineForm Inc.
Stephen, That is not a FL bug, so it will not fixed as it is your file that way (FL is only displaying the metadata is it given.) If new conversions still do it, than report to support with full details and a sample source.
