NeoHD/4K/3D v5.0 public betas now available - Page 4 at DVinfo.net
CineForm Software Showcase
Old May 9th, 2010, 06:45 PM   #46
That's good detective work Stephen... now get back to watching your download.
Marty Baggen is offline   Reply With Quote
Old May 9th, 2010, 06:50 PM   #47
Duplicate post
http://lightinaction.org
"All in the view of the LION"
Stephen Armour is offline   Reply With Quote
Old May 9th, 2010, 06:52 PM   #48
Originally Posted by Stephen Armour View Post
Now I'm sure of it. It's wrapped the right side back to the left, and is clearly the exact two or three pixels of the right side superimposed.
Hi Stephen,
How do I fix it? The 2 layers are the video and the NLP logo?
How come if I revert back to 4.3 the line isnt there? Reinstalling v5 now
David Dwyer is offline   Reply With Quote
Old May 9th, 2010, 06:52 PM   #49
That's just plain evil Marty! How could you know?
(Only 8 hrs to go...I've given in to the power of the RING...gotta sleep...gotta sleep...gotta sleep...)
Old May 9th, 2010, 06:57 PM   #50
Originally Posted by David Dwyer View Post
Hi Stephen,
I'm not sure about your "revert fix," but it sure looks like a simple off-center top layer. It can happen if you accidentally click on the production window sometimes. Easy to identify and fix if it's that simple. Are you sure you don't have a dup copy of your vid under that layer?
If it's a GPU prob, it could be harder.
Old May 9th, 2010, 07:14 PM   #51
Thanks Stephen,
Reinstalled V5
I've removed all effects and just left the video layer, did another export and the line is there.
If export to MPEG2 the line isnt there. Only there in CF AVI.
Added new sequence imported just 1 video - Right clicked on the layers and deleted all empty tracks. Exported again and the line is there.
Old May 9th, 2010, 07:29 PM   #52
David,
I can tell you that I am not able to duplicate your issue.
Just out of curiosity, if you resize your footage in your output, say to 90% or so, is the shift still present?
Have you duplicated the shift with other footage?
Old May 9th, 2010, 07:33 PM   #53
Doesn't sound good David. Have you tried the same thing as a non-CF project? That might isolate the culprit. Another thing to try is to re-interpret the footage, but it could well be a bug that needs to be stomped.
I'd weigh in with support on this one, as it could affect others if reproduceable. V5 is a still in beta, so it's a good thing to look into. You probably should post this separately to call attention to it. If it's a GPU specific prob, others with the same GPU should be able to reproduce it. If it's a possible V5 bug, support should know about it.
Old May 9th, 2010, 07:35 PM   #54
David,
Testing that now and uploading the source footage and a test project file
I tried a Pr default preset and export to CFHD and the line was still there.
Old May 9th, 2010, 07:40 PM   #55
If its set to 90% the line is gone but there is just a little mark on the right still
NeoHD/4K/3D v5.0 public betas now available-mark.png
Old May 9th, 2010, 07:44 PM   #56
http://www.northern-loop.tv/Video/line.rar
There is a test project with 1 project file with the source CFHD AVI - Can someone test that?
Old May 9th, 2010, 07:45 PM   #57
So in my mind, that tells me that Pr is interpreting the footage properly, but it doesn't like it on the output side of things.
What is your source footage? HDV... tapeless?
Would a recapture be a sensible thing to try if not done already?
Old May 9th, 2010, 07:48 PM   #58
HDV from my Z1, used HDLink to capture the M2T file then used HDLink to convert it to AVI.
I dont think a recapture is worth it, when I revert back to NeoHD V4.3 the line is gone.
Can you test the above project with NeoHD V5?
Old May 9th, 2010, 07:52 PM   #59
Will do... but don't have WinRar. Suggestions?
Old May 9th, 2010, 07:53 PM   #60
WinRAR archiver, a powerful tool to process RAR and ZIP files
Or I can reupload it in ZIP?
