#16 | |
I leave this color correction filter on when I am rendering Vimeo or Youtube versions as well, but disable it for Bluray or DVD renders. Also, Vegas text defaults with whites of 255. I adjust them to RGB values of 235,235,235 so that my text doesn't overdrive the TV on DVD or Bluray renders. Another thing that I do is put a cRGB to sRGB color correction filter on any still photos (jpeg or png) that are on the Vegas timeline. Still pictures are always cRGB in Vegas. Yet another thing that I do is put a track of generated 16,16,16 black below all my video tracks so that any fade to blacks don't go below 16. Most of the time this isn't a big deal but twice in my career I've run into either an old CRT TV or video input switcher that loses sync on blacks of 0. It is rare but it is such a severe problem when it happens that I always put the sRGB 16,16,16 black as the bottom track on every project. You can also do the same thing with a broadcast colors filter except then nothing will smart-render. I use the generated black track so that I can still smart-render. The broadcast colors filter will also tame your text whites if they are the default 255 white, but I would rather just set the RGB values on the text below 235 so that this isn't an issue to begin with. |
#17 |
Keith, if I am reading this right, David Newman was saying you applie the sRGBtocRGB filter to the preview output by clicking on the filter addition for the preview monitor the same way as if you are adding it to the time line. This actually works to get the screen to look more like the original file does played in First Light. He further seemed to say the rendered output would not be affected because of where you put the filter, believing that it only affect the preview at that point, but I believe it does affect the rendered output. Thus, you have shut it off before you render, your output should be right. Its just that we apply the filter to make the preview look like what original file looks like.
Chris J. Barcellos |
#18 |
Yes, First Light has the more accurate representation of the color that you will see in the final render. Yet another reason that I like Cineform and FirstLight so much.
#19 | |
Thanks!! monty |
#20 |
Yeap... but changing a .dll in the middle of a 48 hour project has its own risks...... glad it helped.
