Wierd problem at DVinfo.net
CineForm Software Showcase
Old July 13th, 2005, 09:20 PM   #1
Wierd problem
I noticed that when I export to movie a complete 4 min timeline (CFHD codec)
it exports fine and plays great on the timeline, if I export (the movie I just made) to m2t, cineform m2t or main concept mpeg pro m2t, it is green or multi colored, mind you if i use the original captured clips (instead of the exported movie) it exports fine, tried it on another computer (same file) it plays fine but same export problem. No transitions in the clip, any clues? Can someone else try this?
Mike
Michael Stewart is offline   Reply With Quote
Old July 13th, 2005, 11:48 PM   #2
CTO, CineForm Inc.
Did you get the New Aspect HD 3.2 that was re-uploaded this afternoon?
http://www.dvinfo.net/conf/showthread.php?t=47455
Old July 14th, 2005, 12:00 AM   #3
yes david, I did. It worked when exporting to SD DV, but still has the same problem with exporting to m2t files.
mike
Old July 14th, 2005, 12:28 AM   #4
CTO, CineForm Inc.
I'll have to check into this more tomorrow as it is working fine on my home PC with the latest components. Does the failure only occur when you re-import an previous export (which your first post indicates)?
Old July 14th, 2005, 11:59 AM   #5
AJA Video Systems
More Info
Mike,
What resolution are you working in?
When you say 'main concept mpeg pro m2t' does that mean that you have addional main concept plugins installed with premiere?
Thad H.
CineForm
TH
www.aja.com
Thad Huston is offline   Reply With Quote
Old July 14th, 2005, 01:29 PM   #6
Is this version different than the 3.2a I downloaded last night?
Dave
Dave Campbell is offline   Reply With Quote
Old July 14th, 2005, 03:22 PM   #7
CTO, CineForm Inc.
3.2a is the latest, and it should now be working great.
Old July 14th, 2005, 11:38 PM   #8
Update, I installed the 3.2a and it works fine now!
Mike
