Firstlight - Could not Load metadata error
Hello,
I converted 23.976p using the new Canon firmwware and 30p the previous 30.00p firmware files from the Canon 5d mk2. I converrted my files in HDLINK using the following; Quality: HIGH I-Frames Only: un-ticked Frame Format: progressive Prospect HD v4.30 Build 240 Some clips I converted I can open into Firlight fine, but some of the 23.976 and the 30 which are now 29.97p get an error when I bring them into Firstlight. Invalid File Type "Could not load metadata The File xxxx.avi is not a valid Cineform file is corrupted or needs a CFRepair upgrade" I am on Windows 7 64bit Professional, what would likely cause this error? Thanks, Leo |
CTO, CineForm Inc.
Please, upload a small sample file that fails.
David Newman -- web: www.gopro.com blog: cineform.blogspot.com -- twitter: twitter.com/David_Newman |
Hello David,
The Quicktime original or the converted Cineform File? Leo |
CTO, CineForm Inc.
converted AVI.
#5 |
Hello David,
In the process of uploading it says about 30mins via our FTP. |
#6 |
#7 |
CTO, CineForm Inc.
I see the problem, but it is little weird. Much of the audio is stored before the first video frame -- so much so FirstLight doesn't find it. This is easily fixed. In the meantime, load the affected clips into VirtualDub, set Video to "Direct Stream Copy" and save out a new AVI. This will fix it quickly without changing your image.
#8 |
Hello David,
Thanks, after doing the Virtual dub steps you told me I can load these fine into Firstlight and apply my changes. What software did you use to find the audio issue? Thanks again, Leo |
#9 |
CTO, CineForm Inc.
I tried your clip in FirstLight under a debugger. It is not an issue with the file, audio is allowed to be placed that way. The bug was in FirstLight's AVI reader, it didn't expect that much audio ahead of picture.
#10 |
Hello David,
I did my grading, I can open my Firstlight clips in Windows Media Player, Adobe Premiere pro and see the firstlight changes just fine. As soon as I open the AVI files into After Effects it plays back and displays with no Firstlight ajustments? Leo |
#11 |
CTO, CineForm Inc.
what version of after effects?
#12 |
Adobe After Effects cs4 with all the latest updates.
#13 |
CTO, CineForm Inc.
I was expecting you to say AE7 or 6.5, as CS4 use the same importer as Premiere itself -- so anything Premiere does AE will do. I have to think more about this.
#14 |
Hello David,
I wiped my hard drive and re-sinatlled all my software, I used a slightly older version of Quicktime and After Effects is wokring fine with Firstlight so far it seems. Not sure what changed perhaps somehting in Quicktime. Leo |
