Edius 5 at DVinfo.net
CineForm Software Showcase
Old March 28th, 2010, 06:00 PM   #1
Edius 5
My understanding is that Edius 5 is not supported by Cineform, and that this would seem to mean capturing and any sort of integration with Edius' monitoring function or any type of acceleration.
The trial of Edius 5 that I am working with is able to mix HDV, CFHD, (and starting tomorrow I will be able to drop in some EX1 footage!). All clips play smoothly.... realtime transistions, and this with a very modestly powered Win7 workstation with only 4gb of RAM.
The trial version doesn't seem to allow an export to file, which is certainly understandable.
My question is, will Edius see and recognize Cineform as a codec and output to it?
If not, is there any lossless path (short of an uncompressed HD file) to a CFHD file from the Edius 5 timeline?
Is there any reason First Light would not function in an Edius 5 environment? At first glance, it seems to be doing all its usual wonderful stuff.
Marty Baggen is offline   Reply With Quote
Old March 28th, 2010, 09:22 PM   #2
CTO, CineForm Inc.
Didn't even know Edius would decode CineForm files -- if it does that FirstLight will work. I don't know where export codec type it supports. It might use Quicktime, so you can get to CineForm that way.
Old March 28th, 2010, 09:52 PM   #3
Hey David... thanks for chiming in.
The CFHD files work like a charm in the timeline.
What would Edius need to see in order for it to encode to Cineform? Is having the codec installed merely enough, or does an NLE require more integration that allows it to export a CFHD file?
Old March 28th, 2010, 10:22 PM   #4
CTO, CineForm Inc.
Most NLEs use standard codec APIs for export. CineForm has implemented all of them, VfW, DirstShow and Quicktime, Edius should should at least one of these.
Old March 28th, 2010, 10:27 PM   #5
I will dig deeper on that front. In the meantime, CFHD with First Light adjustments are playing back smooth as silk in the Edius 5 timeline. I'm sorta stunned.
With the simultaneous and realtime vector/waveform window, the First Light adjustments are even easier than ever and rapidly becoming my favorite part of the entire Cineform package..... it's brilliant.
