OT: need to get Sergio Garcia's attn.!
Hello Sergio!
My name is Vanja, from Zagreb, Croatia... However, I recently bought Canon 5D MkII and now I am researching possibilities of editing its footage. Like you, I also got Cineform NEOSCENE and had very similar problems as you did (about yellow lines and presets in PPRO CS4) I also have that problem that my other (or, if you want, MY FIRST) Camcorder is Sony FX-1 (HDV - 1080i) PAL So, now I have footage from that camera which, after cineform, 25i and from Canon which are 25p! Now I don't know which preset to use to put Interlaced and Progressive footage on the same Timeline! But what I wanna ask you is something else! At the end of your post on DVinfo.net Forum you say that you have IntelQUADcore 2.66, which you overclock up to 3.2GHz... I have exactly the same CPU!!! Can you tell me which numbers did you put into your BIOS to make it run so fast! I've tried few times, but it would crash very soon, or not boot at all! I run that CPU on GIGABYTE MOBO with latest Intel chipset for LGA 775 processors... Have 4 GIGS of RAM (planning to get 4more) - My system disk is 74GB WD which runs on 10000rpm and OS is Win7 64bit... So, if it's not a problem, can you please read out those numbers from BIOS - (did you just change multiplier or also something else and did you touch Voltage current) Sorry for bothering you and thnx in advance! V. vanja.marin@gmail.com |
