I frames only? at DVinfo.net
CineForm Software Showcase
Old March 16th, 2010, 02:44 PM   #1
I frames only?
In HDLink in preferences under CineForm Encoder Options there is a check box for I frames only. I would like to know what that is for. I didn't see it in the manual. Thanks!
Marc Brackhahn is offline   Reply With Quote
Old March 16th, 2010, 02:57 PM   #2
CTO, CineForm Inc.
It was called "smart rendering", but that is more obfuscated than I-frame mode. All it means is frame as store separately within the AVI/MOV. It is useful for 3D projects, and lossless smart renders in Vegas. Leave it on if you don't understand the need, turn it off you want to save 15% disk space for the same quality.
Old March 18th, 2010, 02:41 AM   #3
So leaving it off has the same quality as having it on? I use vegas, whats the benefit?
mintyslippers.com
Danny O'Neill is offline   Reply With Quote
Old March 18th, 2010, 09:10 AM   #4
CTO, CineForm Inc.
Same quality yes. In Vegas you go lose smart rendering.
Old March 18th, 2010, 02:41 PM   #5
I use Vegas and I love the smart-rendering, but now I'm wondering:
If I use First Light for my color correction, I'm losing the ability to smart-render anything that I've adjusted the color on. Is that correct? I might as well uncheck it and save the space.
Here's another question. When I do documentary stuff, I light the interviews, set white balance, make sure everything is perfect before I shoot it. I rarely need any sort of correction.
However when I shoot B-Roll, I use a lot of auto settings and a little color correction helps quite a bit.
Any problem mixing I-frame and non I-frame footage? Does Vegas just smart-render the I-frame parts and fully render all the non I-frame parts?
Laurence Kingston is offline   Reply With Quote
Old March 18th, 2010, 03:25 PM   #6
CTO, CineForm Inc.
Yes, No, and Yes to your questions. All will work as planned.
Old March 20th, 2010, 07:30 PM   #7
There's no "I-frame" setting in the vfw codec settings that Vegas uses. Am I correct in assuming that anything rendered in a vfw application like Vegas or VirtualDub is automatically using I frames?
Old March 20th, 2010, 10:51 PM   #8
CTO, CineForm Inc.
Yes, this has always been the case. Creating long-GOP (even two frame GOP like CineForm can be) never worked with VfW tools. VfW and QuickTime are treat as I-frame always, whereas DirectShow didn't care.
