New CineForm release now available. - Page 2 at DVinfo.net
CineForm Software Showcase
Old March 17th, 2010, 01:56 PM   #16
I Frames?/update PDF manual
With latest update:I tried to convert a file thru HDLink from a XH A1 Canon 24F. the resulting file had a longer audio and than video track. I then used converter and it worked fine. Then I checked the undocumented (in the accompaning PDF manual) 'I- frames' only and it worked fine. The manual does reference 'smart rendering' which is no longer there. Please update the manual and tell me the proper way to convert a Canon 24F file thru HDLink.
Thanks.
Roy Feldman is offline   Reply With Quote
Old March 17th, 2010, 02:44 PM   #17
CTO, CineForm Inc.
Roy,
Sorry I don't understand what issue(s) you are having, or you are report just an observation (some clips have extra audio.) Please file a trouble ticket is something isn't working.
Old March 19th, 2010, 01:33 AM   #18
No Sound
I downloaded the latest. Install failed
I re-installed and conversions worked but I have no audio. What's up? Anyone else have the same problem?
George Hsia is offline   Reply With Quote
Old March 19th, 2010, 05:08 PM   #19
same...no audio after conversion...
Chris Light is offline   Reply With Quote
Old March 20th, 2010, 01:05 PM   #20
I need help
I've submitted a trouble ticket but no response. Can anyone help? I ran a conversion on pre 2.0.3/4 FW. This is killing me. Every time I run an update the system stops working and I seem to need to ask for help. Anyone have a resolution to this?
I'm running conversions on my laptop running Vista 64 with latest patches and 8 GB of RAM. Thanks.
George
Old March 20th, 2010, 08:56 PM   #21
This is from Cineform's techblog - might help ....
NOTE about Audio: If you are not properly converting audio, you may not have an AC3 decoder installed. Many software packages install an AC3 decoder, but if not, you can get a free AC3 decoder here: Free-Codecs.com :: Download AC3 Filter 1.63b : AC3 Filter is a DirectShow filter for AC3 decoding.
Old March 20th, 2010, 08:59 PM   #22
Thanks Graham. Would seem odd though as it used to work fine with audio and all of a sudden with the last update it stopped working. I find it a bit odd.
Old March 21st, 2010, 02:49 PM   #23
YES. Same here too. No audio with the latest version of NeoScene.
Rich Ryan is offline   Reply With Quote
Old March 22nd, 2010, 06:18 AM   #24
Having recently aquired a Canon T2i and shooting with that as opposed to my V1U, using meta-data has become more attractive to me. First Light is an excellent tool to make use of this information and I thank Cineform for including it. Are there plans to include this access in Premiere Pro natively, or will First Light always be required? I suppose since Adobe uses its own language of XMP it's either licensing or a lot of unnecessary conversion/coding, is that it?
Craig Irving is offline   Reply
