Cineform Neo HD Trojan at DVinfo.net
CineForm Software Showcase
Old February 20th, 2010, 10:15 AM   #1
I already have neoscene and uninstalled it to try out Neoscene HD. However, while installing it my McAffe anti-virus said it had a trojan and blocked it. Has anyone else had this problem
Marc Brackhahn is offline   Reply With Quote
Old February 20th, 2010, 11:20 AM   #2
CTO, CineForm Inc.
There is no trojan. Sometimes anti-virus tools get upsetting over the way the quicktime codec is protected, they think it is odd and generate a false positive.
Old February 20th, 2010, 11:29 AM   #3
Thanks Dave, but what do I do?
Old February 20th, 2010, 11:40 AM   #4
CTO, CineForm Inc.
I guess disable McAffe for the install.
Old February 20th, 2010, 02:39 PM   #5
Well, I disabled it and now it downloads but it just won't work and then crashes.
Old February 20th, 2010, 02:43 PM   #6
CTO, CineForm Inc.
Sounds like your PC has issues, as crashes you should not see. Submit a trouble ticket here Support Center
Old February 20th, 2010, 03:43 PM   #7
I can assure you my PC has no issues. It is a couple of months old and has performed flawlessly until I tried Neoscene HD. It works perfectly with Neoscene just not Firstlight. I sent in a ticket BTW, Thanks!
Old February 20th, 2010, 04:00 PM   #8
CTO, CineForm Inc.
First Light is not part of NeoScene, only Neo HD/4K or 3D, don't mix versions as that can be a problem. If you a very new PC, you maybe missing some DLL components, that what I meant by issues. If you where using Neo HD, trying running First Light as Administrator, once normally does the trick, although this isn't to fix a crash but some Windows 7 systems have permissions issues.
