10 bit Cineform out from Combustion Part 2 at DVinfo.net
CineForm Software Showcase
Old December 31st, 2009, 03:56 AM   #1
Hi All.
Tried to export 10 bit 1280 x 720 file without Alpha channel from Combustion 4 thru quicktime and got this Error message:
"Licensing Error. You are attempting to encode a format for which this system is not licensed. Please contact support@cineform.com"
If I switch the mode to 8 bit then it works but it is 8 bit...
I have ProspectHD that runs on Windows XP 64 bit
The Forgiveness A Film About Life
Jan Tervo is offline   Reply With Quote
Old December 31st, 2009, 10:51 AM   #2
CTO, CineForm Inc.
Ah yes, I hadn't thought of that. 10-bit RGB is not something PHD will encoding only P4K/N4K. The codec will not automatically convert deep RGB to 4:2:2 on PHD, causing the licensing issue. Care for a end of year discount on a P4K upgrade?
