Corrupted frames in Cineform transocded clip. at DVinfo.net
CineForm Software Showcase
Old December 16th, 2009, 02:04 PM   #1
I loaded up a Cineform clip today and the first 2 frames of the clip were corrupted. I freaked out, thinking perhaps my HMC150 had recorded these corruptions so I went back to the original MTS file and the frames were clean. Has anyone ever seen these types of corruption by Cineform?
http://img231.imageshack.us/img231/7...ormproblem.jpg
A problem I observed while transcoding about 640 AVCHD clips to Cineform -Twice in the process, Cineform would hang while transcoding a clip. I would walk away for a period of time and when I got back, I noticed that Cineform had stopped running and my RAID array had gone to sleep. HDLink's progress bar was stuck. I would kill the app and whatever progress had be done on that last clip was already saved to file and I could actually play the clip. Strange since I would have assumed the last clip would be unplayable. I'm not sure if the problem with this clip is related to the behavior I observed..
Old December 16th, 2009, 02:10 PM   #2
I should also add that this clip was the 2nd of a series of disjointed long clip produced by the HMC150.. The maximum file size is 4GB and the HMC automatically creates a new file after it reached 4GB...
That being said, I have other clips disjointed like the one above and Cineform converted those just fine.
Old December 17th, 2009, 04:45 PM   #3
Just found another "spanned" clip that has corruption on the 1st frame after transcoded to cineform...
Old December 17th, 2009, 05:05 PM   #4
CTO, CineForm Inc.
I don't know why that is. Likely there is something incompatible with the Main Concept decoder or upstream demux we use. I gather these are large (source) files, maybe you could burn a sample to DVD-ROM (send to support,) so we could test why this is happening.
Old December 18th, 2009, 12:35 PM   #5
Yeah there must be some inherent incompatibility between Cineform and how the spanned clips are individually packaged. However, I've modified my workflow to joining the spanned clip first, then transcode...
Old December 20th, 2009, 07:39 PM   #6
I have the same problem since the thanksgiving beta and now I installed the latest build
and I still have the corrupted frames on serveral clips.I captured the same footage in adobe native and had no problems .All this is done in CS3
thanks Rudy
Rudy Wilms is offline   Reply With Quote
Old December 20th, 2009, 07:49 PM   #7
CTO, CineForm Inc.
It is unlikely to have anything to do with the betas, as the HDV capture engine hasn't changed in a very long time. Contact support as they will help you solve the issue.
