Neoscine Trial at DVinfo.net
CineForm Software Showcase
Old December 15th, 2009, 09:34 PM   #1
Neoscine Trial
I tried neoscine for the first time using HDV footage from the fx1000 to Vegas 9c.
when playing the clips out of Vegas the clip was choppy and when play it on the time line it was very choppy on best.
As well the files seems to be bigger then the original file.
Did i do something wrong?
www.nostalgicFrames.com
Dror Levi is offline   Reply With Quote
Old December 15th, 2009, 09:50 PM   #2
CTO, CineForm Inc.
Vegas works best an Preview Half with CineForm media. The files are supposed to be bigger than the original as the original is heavily compressed and the CineForm are not (the size helps with multi-generation quality.) Vegas does a pretty good job for play HDV files, is main advantage NeoScene is the 24p pulldown exaction and the quality reserved through multiple generation, while moving images from one application to another. AVI wrapper is also convenient.
Old December 16th, 2009, 09:05 AM   #3
So if I understand correct I am not going to benefit from simple HDV editing with Neoscine.
I hope to get better Result with the 7D files.
Thank you for the input
Old December 17th, 2009, 10:18 AM   #4
CTO, CineForm Inc.
You benefits if your source is 24p with HDV, otherwise NeoScene particularly helps AVCHD cameras and Canon V-DSLR sources.
