PC updates to version 4.1.2 officially out. - Page 2 at DVinfo.net
CineForm Software Showcase
Old October 26th, 2009, 09:08 PM   #16
CTO, CineForm Inc.
Do please submit a report, as the 3d exports are needing enhance. They are primarily designed for preview, a full quality side-by-side is better in a two parse (export left then right and mix.)
Old October 26th, 2009, 09:17 PM   #17
CTO, CineForm Inc.
Forward to support so they can confirm.
Old October 26th, 2009, 09:18 PM   #18
A little more information...
I did more tests and found the following:
All were exported from PP CS3 from a muxed 1920_1440 file.
The file shows correct color information and stereo information in Premiere.
I have tried multiple files and at different resolutions with the same results.
When exported from Premiere changing 3D Display Type in First Light...
Anaglyph Red/Cyan - good color information/good stereo information
Anaglyph Amber/Blue - good color information/good stereo information
Interlaced - good color information/lost stereo information
Onion Skin - good color information/good stereo information
Difference - can't tell
Over-Under - good color information/lost stereo information (left eye only top and bottom)
Side-by-Side - lost color information (B&W)/lost stereo information (left eye only on both sides)
On occasion an export will return a file with green bars only and a hint of image.
David H. Wilson is offline   Reply With Quote
Old October 26th, 2009, 09:19 PM   #19
CTO, CineForm Inc.
Forward to support please.
Old October 26th, 2009, 09:39 PM   #20
I will send this information on to support but
Hmmmm... I think I'm missing something about the workflow. I had thought I would 1)convert right and left eye files to CFAVIs. 2) Mux R and L files together in First Light. 3) Correct orientation and color correct the Muxed 3D file in First Light. 4) Import Muxed 3D shots into Premiere and edit. 5) Export the completed project from Premiere in Side-by-Side 3D Display Type for presentation with Stereoscopic player.
The things that confuse me are how do I correct Orientation if not on a Muxed file? And then how do I create a side by side of the finished edit if not from a Premiere export?
We shot side by side mirror box and are breaking the Right and Left eyes into separate files doing two windowed R2CF passes for each file (thanks to your insight to do this earlier this year).
I'll send what I've found about the exports on to Jake.
Thanks for the help.
Old October 27th, 2009, 01:07 AM   #21
if you got the files muxed and using steroscopic player, you can ask the player to play side by side (or over 2 different screens) , so there is no need to demux ?
Old October 27th, 2009, 08:35 AM   #22
CTO, CineForm Inc.
We will address bugs in the side-by-side rendering. However, we don't consider side-by-side a finishing format, just a hack for displaying on today's 3D tech. With blur-ray 3D just around the corner, and theatrical presentations, only full resolution per eye with do.
Old October 27th, 2009, 12:44 PM   #23
David and Giroud,
A light finally went off in my head and I understand that side-by-side, interlaced, anaglyph etc. are really for previewing only (which is great).
So I'm assuming then to output edited 3D Premiere timeline I would set First Light to Left Eye and export from the Muxed edited timeline yielding an edited Left Eye file of the edited piece. And then set First Light to Right Eye and export the timeline again yielding a Right Eye file of the edited piece.
Am I loosing resolution exporting Left and Right Eye files from the Muxed master? If I'm not, this makes perfect sense. I definitely need full resolution for each eye.
I think, however, I'm experiencing a bug in First Light such that whether I have First Light 3D Display Type set to Left or Right Eye the resulting file is always only Left Eye.
Old October 27th, 2009, 04:14 PM   #24
In fact i still have to find a manual (or any description) to work in 3d with cineform.
I am not even sure that ProspectHD is supporting it, since 3D is advertised only for Neo3D.
Anyway, you can easily get work on the left side into a project and then replace all clips with the right side, by just switching between two folders.
When you got both sides rendered, you can mux them, depends the format.
Muxing is not supposed to reduce resolution, since it is just adding another stream of video in the file structure.
but it will give huge files, so if you know the technology used to display, you can build a file that keeps only the necessary data .
For example in you use interlaced display, you can skip half of the lines in each file.
If you use page flipping or dual projector, then it is better to keep the two streams intact.
I doubt that your final encoding will be in Cineform codec, but rather a WMV or mpeg2 file if you want to distribute easily.
Old October 28th, 2009, 10:47 AM   #25
Giroud,
Thank you very much for your reply. Actually CineForm (just at the end of last week) released Prospect3D (the PC equivalent of Neo3D). I am using a trial right now. It is not inexpensive but from our perspective the primary advantage is that it allows us to do corrections on our shots - specifically we can get the convergence fine tuned, fix any vertical discrepancies and adjust any skew as well as color work. We shot with a mirror-box (on a 4K sensor) so the two streams are always in good sync. Our first step with any shot is then to break it into two independent streams that we then mux together through p3D.
We were very careful in our shooting and thought the 3D was pretty good on our shots but when we look more closely through Prospect3D, it turns out that some correction (throughFirstLight3D) on every shot makes it better. Our hope with the CineForm product is to be able to have all of our shots with the stereo and color correction just where we want them (as metadata) in a single muxed Premiere timeline and for finishing export from that timeline both a Right and Left Eye stream which we can present in our small theater through Stereoscopic Player (great tool) on a Mitsubushi DLP. P3D is nice in that it allows us to preview our edit as we work in 3D through anaglyph, interlaced, cross-eyed or whatever means we choose.
That's where we stand. The product (P3D) is very new and I think there are still a few bugs in it. I may be doing something wrong but at the moment from the Premiere Muxed timeline I am able to only export a Left Eye stream of our edit (no matter what setting I use in First Light) which is forcing me to build in Premiere another Right Eye version above the Left Eye which it seems I shouldn't have to do.
Thanks again for your thoughts.
Old October 28th, 2009, 11:21 AM   #26
that's a great news, because i am using Premiere CS3 and found that dual editing is a bit tedious without proper preview. I use 2 Sanyo FH1 parallel mounted (2 inches space between center of each lens). I made some test and it seems there is no need for any adjustement and rushes are ok right out of the SD card
i got 2 Optoma EP1080 for display with circ. polarizer, so i need both stream with completed resolution and frame rate for the big screen
I use a Zalman 22" 3D monitor for 3d preview/editing , but it use interlaced, so in that case the full res is not necessary (half of the vertical lines are skipped by the player)
it would be great if i could activate preview in 3D from premiere on the zalman.
Old October 28th, 2009, 10:59 PM   #27
Giroud,
Although I don't have a Zalman (actually will likely get one tomorrow for another purpose however), I'm all but sure that P3D will support interlaced preview on that monitor.
