1920x1080 60p files from Sanyo VPC-FH1 at DVinfo.net
CineForm Software Showcase
Old October 17th, 2009, 05:00 PM   #1
Does anyone have any experience with 1920x1080 60p files from Sanyo VPC-FH1? Will Cineform NeoScene convert these files?
Jim Snow is offline   Reply With Quote
Old October 17th, 2009, 05:57 PM   #2
Are they .mp4 or .mts? Or something else?
Old October 17th, 2009, 08:53 PM   #3
I don't have the camera so I haven't had any hand's on with the files from this camera. The files are MPEG-4 AVC/H.264 however I heard someone make a comment that Sanyo's version of the codec is a little "different". I'm hoping to hear from someone who has actually used the camera.
Old October 17th, 2009, 09:31 PM   #4
I have a Samsung HMX104 that generates 720p60 MP4 AVC/H.264.
Cineform's HDLink struggles with the footage - I have been able to transcode to CFHD at times, but it gets the framerate wrong and I have to correct that with separate software. I filed a trouble ticket - Cineform says they are waiting on improved AVCHD routines.
The complicating factor I've found is that different machines behave in different ways depending on what other AVC and AC3 codecs and splitters are installed.
Hopefully someone with the Sanyo will respond.
Old October 19th, 2009, 06:46 AM   #5
I have the camera
HI - I have the Sanyo FH1, and was able to transcode the footage using HD link until a couple of Prospect 4k updates ago, now it gives me an error message saying that there is no decoder for it, HD link still transcodes the footage from a Sony AVCHD camera though.
The footage will play natively in PPro CS4 though it would be great to be able to use HD link, in part because I'm having to shoot sometimes with the camera upside down.
The files are mpeg4 avc, and I remember that when I shot some footage using 60fps it was a pain and had to go through two processes - sorry I can't remember what they were now, only that I made a mental note to shoot 30 fps from now on. Nice camera though, now I just need to be able to convert through HD link with a frame rate (30 - 25) change and a 180 flip.
Time to submit a ticket.
Let me know if you want a sample file.
Billy
Billy Payn is offline   Reply With Quote
Old October 19th, 2009, 09:05 AM   #6
Billy, Thank you for the input. I would appreciate a small sample file shot at 1920x1080 60p. I will report what I observe.
Old October 19th, 2009, 03:32 PM   #7
this is 60 fps xacti FH1
Here's a file please let me know what you manage to do with it.
I managed to get HD link to convert this before, not recently though, and it still needed rendering in CS4
Billy
Old October 19th, 2009, 03:42 PM   #8
HI I've tried to attach a file - it's only 42 mb though it's bigger than the attachment manager says is the max, ie it's 1920 1080 if it wont attach, I can transfer it to you via a file share.
Billy
Old October 19th, 2009, 06:02 PM   #9
Hi Billy,
Can you use Yousendit to send the file to support@cineform.com?
We'd love to take a look and see what's required to get it converting properly.
Tim Bucklin
CineForm Software Engineer
Tim Bucklin is offline   Reply With Quote
Old October 19th, 2009, 06:44 PM   #10
Hi Tim, As usual, you guys are on top of things - - amazing. If you get the file, can you post your observations in this thread? Thanks.
Old October 20th, 2009, 10:51 AM   #11
Hi Guys
you can get a file here;
https://download.yousendit.com/YkxLL0dPd0E3bUJjR0E9PQ
Regards
Billy
Old October 20th, 2009, 04:14 PM   #12
Hello all,
It looks as if all you need to do is register the AVCHD decoder which is currently not being registered. It's supposed to load automatically but, for whatever reason, is not doing so.
the file is "mc_dec_avc_ds.ax" and it's in the same folder as HDLink. So, for Neo Scene users:
"[root]\Program Files\CineForm\Neo Scene" (32-bit OS)
"[root]\Program Files (x86)\CineForm\Neo Scene" (64-bit OS)
For other Neo and Prospect uses, just replace Neo Scene with your corresponding product.
Double-click on that "mc_dec_avc_ds.ax" and it should register. If it asks which program to open it with, navigate to "[root]\Windows\System32\regsvr32.exe"
This should get these files converting properly on your machines. Meanwhile, I'll figure out what's special about this camera's clips that's preventing conversions from working normally.
Tim Bucklin
Old October 23rd, 2009, 01:47 AM   #13
Yup
The VPC-FH1 produces MPEG-4 files containing AVC and AAC streams. This is not precisely AVCHD, which is an MPEG-2 transport streaming containing AVC and AC-3 streams.
Cineform Neo will convert these just dandy.. I have this camcorder, and have used it. The 1080/60p video comes out a bit over 100GB per hour.
--Dave
Dave Haynie is offline   Reply With Quote
Old October 23rd, 2009, 11:36 AM   #14
Quote: AVCHD, which is an MPEG-2 transport streaming containing AVC and AC-1 streams.
I thought AVCHD was MPEG4 (H.264 and AC3)?
Old October 23rd, 2009, 01:22 PM   #15
My Bad
Yeah, SMPTE AC-3... I had VC-1 on the brain, sorry.
--Dave
