Cineform Workflow help at DVinfo.net
CineForm Software Showcase
Old October 17th, 2009, 10:58 AM   #1
Hey all. So im looking for some workflow help. Basically i have a Canon HV20, which outputs to HDV .mts files. What i used to do before was use cs3 on xp with cineform. I would import my files into Premiere, do my editing, and export out as a cineform file with aspecthd. Then i would import that into After Effects and use the Export > Quicktime option so i could export the file out as a Quicktime H264/AAC compliant file. Everything seemed good and such.
Well ive now gotten Windows 7 and purchased CS4 and ProspectHD. But now when i do my same workflow, it seems as if the quality after the quicktime export is not as sharp and clear. Im not sure why, maybe im seeing things. What im wondering is, is there anyway i can use Quicktime Pro with the exported cineform file and skip using after effects all together? Ive tried opening the cineform file with quicktime and exporting but when the export is finished im left with a weird black encoded file that is just a bunch of colors outlined of the video.
Im just trying to get the best quality possible out of CS3 or CS4 into a Quicktime H264 compliant file for web streaming.
Matt Young is offline   Reply With Quote
Old October 17th, 2009, 02:57 PM   #2
I have had better luck encoding H.264 files in CS3 than CS4. Make your Cineform HD master regardless. Then compare these options:
Export H.264 from AE CS3
Export H.264 from AE CS4
Export to H264 directly off your Premiere Timeline
Rewrap your Cineform AVI to an MOV in HDLink, and then use QT-Pro
Compare all those files to see which has the best quality. I suspect AE CS3 will give you the best quality for the least work.
For more information on these topics, check out my tech website at www.hd4pc.com
Mike McCarthy is offline   Reply
