Playback on HDTV at DVinfo.net
CineForm Software Showcase
Old October 13th, 2009, 02:59 PM   #1
Playback on HDTV
System specs are:
Windows Vista Ultimate
Intel i7 920 2.67 GHZ
12 GB memory
64 bit OS
ATI HD 4800 Series
1.5 TB Raid 0 internal drive (project files)
1TB WD internal drive (Back up and assorted files)
2 500 GB WD Raid 0 drives for OS
I firewire out from pc to a JVC analog recording deck/playback device(SR-VS10). and then composite out to a HDTV
Image on HDTV is very narrow in appearance on screen.But width is fine.Image in project window is normal.
If I make any changes in size/scaling (even 1 point ) the image will play back fine.
No problems with M2t files ,they playback fine, only with Cineform PHD when converting the M2t's through HDlink.
Any thoughts...settings I can adjust for playback on xternal monitor?
Billy Snider is offline   Reply
