HDLink Converted Files Don't go to Chosen Folder...? at DVinfo.net
CineForm Software Showcase
Old October 10th, 2009, 01:25 AM   #1
I have started to use HDLink to convert files to Cineform (Prospect HD v4).
I choose convert tab.
I select the file to convert.
Then, I "Select Folder" thinking the converted file will go in this folder.
However, the converted file goes into the same folder as the original file.
What am I doing wrong?
Old October 10th, 2009, 02:29 AM   #2
What happens if you do it the other way?
Go to Prefs > Select the directory you want your converted files to land in > Select the files you want to convert > Click on Convert to start.
/Roger
Roger Averdahl is offline   Reply With Quote
Old October 10th, 2009, 09:04 AM   #3
Folder is a selection that tells the program to convert all files in that folder. Preferences lets you set the destination folder.
Paul Cascio
www.pictureframingschool.com
Paul Cascio is offline   Reply With Quote
Old October 10th, 2009, 11:00 AM   #4
Thank you! I didn't notice the box under the Capture Location in Prefs that says, "Use Capture Location for Converted Files."
I checked the box and converted files go there with no problem.
Jack Walker is offline   Reply
