#91 |
CTO, CineForm Inc.
Aspect HD 4.1 - public beta
Last week there was an invite only beta release for adding HXV200 support (which seems to be working well -- more feedback is welcome), now this is beta release for everyone else. I expect no majors changes between now and its official release (other than the manual is being updated.)
So if you want the latest and a last chance to help squash a bug (link removed.) This version also others 15 days additional trial time for those who have tried Aspect HD before. Features and Fixes: • HDLink has been updated to support MXF files from the HVX200. • HDLink now supports scaling of MXF or M2T files to various standard HD resolutions. • HDLink now supports deinterlacing of 1080i sources in a progressive output. • Pulldown removal and deinterlace filters can be combined to generate 24p from 60i sources. • HDLink can now convert to a separate output directory. • Export to Frame now better color handling under PPro 2.0. • Timecode capture within Premiere Pro now working again (bug in 4.0.3.)
David Newman -- web: www.gopro.com blog: cineform.blogspot.com -- twitter: twitter.com/David_Newman |
#92 |
CTO, CineForm Inc.
Aspect HD 4.1 has been released now at www.cineform.com.
#93 |
installed (several time) but just a question about the dual premiere 1.5/2.0
lauching prem. 2 shows cineform splash screen with 4.1 launching prem.1.5 shows cineform splash screen with 4.0 how do i know if premiere 1.5 is using the good version or how can i upgrade both premiere ? (dont tell me to reformat Hard disk....) |
#94 |
Text for HD and SD w/ PPro1.5 & Aspect HD
Hi everybody,
I have a workflow issue and I'm curious if others have had similar issues and discovered elegant solutions. I have an HDV project edited using PPro1.5 and AspectHD. I want my final product available in both an HD format (say, WMV files) and SD DVD. When I create text and titles in the HD PPro project and create the HD WMV file, they look fine. However, then when I export to a 720x480 CineformAVI for the DVD, the text is aliased/subsampled and ends up looking excessively blocky sometimes. If I export the edited video without titles to a 720x480 CineformAVI and then recreate the titles natively in the 720x480 project, they look much better even though they are the same size resulting in the 720x480 AVI. Is there an elegant way to create the text/titles once and then scale them appropriately for both projects so that they look clean in both, without having to go through and manually change each and every title file? Thanks in advance for any tips, Bill |
#95 |
CTO, CineForm Inc.
Go into the plug-ins folder with PPro2.0 and find the CineForm directory, copy that into the same place in 1.5.1. Now you have 4.1 in both.
#96 |
CTO, CineForm Inc.
Bill,
Could you please send me is a frame grab of each example? Maybe there is something we can do. David.
#97 |
For what it's worth, I think that this problem is another case of using the wrong field first. I was using native 24p footage in a 29.97 project. When I tried to export using the Lower Field First, it ended up flipped, whereas when I exported using Upper Field First everything looked OK. This seemed most visible in the text, so I thought it was a text only issue, but upon closer inspection I see the problem also in the video footage.
Sorry for the thread... Bill |
#98 |
Is the deinterlace algorithm in HD-Link intelligent, or does it just discard every other field?
#99 |
CTO, CineForm Inc.
It is more intelligent than that, yielding a higher vertical resolution.
#100 |
David, You guys ROCK! I just installed 4.1. The deinterlacing and conversion from 1080i to 720p in HD-Link works great. Incredibly fast too.
Thanks for always making a great product better. Last edited by Mick Guzauski; May 18th, 2006 at 09:54 PM. |
#101 |
Cineform Aspect HD Question.
I shot on miniDV using 2 cams. (1 HVX-200, 1 JVC GR-DVL520U...not real hi-quality, I know,
but the only other storage media I have for the HVX is 2 4GB cards - WAY too little for what I needed). File Props for all footage = Type: AVI Movie; Image Size: 720 x 480 Pixel Depth: 32 Frame Rate: 29.97 Am editing with Adobe Prod Suite, and have Aspect HD installed. Some shots I need the Zoom effect, (not the PPro transition), to cover some camera flubs. While PPRO seems to NOT have Zoom as an effect, the Aspect HD Link has a "Pan, Zoom, Rotate" effect. I've used that, and got what I needed, but I lose sharpness in the resulting "Zoomed" clip. I need to retain sharpenss, and I did NOt capture using Aspect HD. Should I have used Aspect for capture? Can I? Would it help retain sharpness? Addendum: I just realized this may not be entirely clear. In simple terms, will/can Aspect HD do anything to help if I did NOT shoot in HD? All input appreciated.
Denis ------------ Our actions are based on our own experience and knowledge. Thus, no one is ever totally right, nor totally wrong. We simply act from what we "know" to be true, based on that experience and knowledge. Beyond that, we pose questions to others. Last edited by Denis Danatzko; August 27th, 2006 at 11:42 AM. |
#102 |
Unfortunately...
Aspect HD won't help. Whatever you do, you will always lose some sharpness when zooming-in on an image during editing.
By the way, Premiere CAN zoom: go to "distort" in the video effects bin and you will have a way of scaling your images. If you have "InstantHD" from Red Giant, you could upconvert your images to HD and then zoom them out. It could produce better results. |
#103 | |||
THANKS for the reply.
THANKS again.
Denis ------------ Our actions are based on our own experience and knowledge. Thus, no one is ever totally right, nor totally wrong. We simply act from what we "know" to be true, based on that experience and knowledge. Beyond that, we pose questions to others. |
#104 |
what size does aspect hd capture at?
1920x1080 or 1440x1080? leaving settings at default cept ticking on deinterlace. I thought it did it at 1440x1080 auto but I see a setting in the resize video to change it to 1440x1080.
#105 |
CTO, CineForm Inc.
All 1080 HDV is 1440x1080. Aspect HD without a resize is 1440x1080. The resize option is to upconvert 720p or for P2 users to upconvert 1280x1080.
