Can't convert at DVinfo.net
CineForm Software Showcase
Old February 8th, 2005, 12:59 AM   #1
Can't convert
Have two systems that run Prem Pro and AspectHD. One system captures converts to CineForm no problems. Second system video will capture to .m2t no problem but will not convert to CineForm. Same cam, same tape, same cable.
Tech support seems dead in the water. Any ideas?
Camera settings the same. Both sytems i865 chipset. Have done full re-install of both Prem Pro and AspectHD including newest update.
Help!
Ken
Damnit Jim, I'm a film maker not a sysytems tech.
Ken Hodson is offline   Reply With Quote
Old February 8th, 2005, 07:35 AM   #2
RED Code Chef
You have to see what all the differences between the systems
are. 64 bit cpu versus 32 bit cpu? XP Prof versus XP Home?
Service Pack 1 versus 2? Perhaps you are low on diskspace on
some or all of your drives etc.?
Rob Lohman, visuar@iname.com
Old February 8th, 2005, 10:01 AM   #3
CTO, CineForm Inc.
Ken,
Will that system export to CFHD from a Premiere Pro timeline? This will test one of the encoders. There are now two encoding components in Aspect HD, did tech support ask you to re-register these components?
C:\Program Files\Common Files\CineForm\Encode.ax
C:\Program Files\Common Files\CineForm\Encoder2.ax
Old February 8th, 2005, 01:27 PM   #4
Support asked me to re-install AspectHD (newest) and Premiere Pro. They did not ask me to re-register those components.
I have not tried to encode from the timeline. I will do so asap.
Old February 8th, 2005, 01:32 PM   #5
CTO, CineForm Inc.
Re-installing should be as effective as re-registering. Do check that the two encoding components are were they should be.
Old February 8th, 2005, 11:59 PM   #6
Hi there.
The files CFEncode.ax and CFEncoder2.ax are there.
I placed a .m2t file (renamed to .mpg) into the timeline and rendered sucessfully to CineForm .avi
Now if we can just get it to convert when captured we will be in business.
Old February 9th, 2005, 12:08 AM   #7
CTO, CineForm Inc.
Thad said he should be calling you to help out.
