Canon HFS100 + Cineform NeoScene settings at DVinfo.net
CineForm Software Showcase
Old September 4th, 2009, 11:10 AM   #1
I own a PAL Canon HFS100 and shoot in the PF25 mode.
As I understand it, this mode records 25p, but puts it in a 50i stream for playback on TVs.
What would be the best NeoScene Frame Rate settings to get true 25p?
Should I use Deinterlace or Convert to 24p?
Or does this camera actually produce true 25p images, so I should be using Maintain Source Frame Rate?
Thanks in advance!
Last edited by Anthony Mwamwenda; September 4th, 2009 at 11:17 AM. Reason: Clarity
Anthony Mwamwenda is offline   Reply With Quote
Old September 4th, 2009, 11:51 AM   #2
CTO, CineForm Inc.
Two options, deinterlace (not ideal but works) or set nothing and interpret footage in your NLE to progressive.
Old September 5th, 2009, 11:44 AM   #3
Thanks for your reply, Dave!
I think I'll go with the "Maintain Source Frame Rate" option.
So, "Convert to 24p" is a no-no for PAL footage? I know that the actual software says "NTSC Only" next to the check-box; but the manual says that this option can also be used on PAL footage.
Quote from NeoScene manual:
"With Convert to 24p selected, Neo Scene will extract 24p from your source (25p for PAL
users) to produce true progressive files..."
Is this a misprint?
