Which to Get? Intensity Pro or MX02 Mini? at DVinfo.net
CineForm Software Showcase
Old August 5th, 2009, 12:48 PM   #1
I have CS3 and will probably upgrade at some point before too long to CS4.
Computer is an i7 and I have ProspectHD.
I want to add a card for playback on a 60HZ HDMI monitor. (Most video is 24p, but I believe both BlackMagic and Matrox will playback over 29.97/59.94... correct?)
Which should I get, the BlackMagic Intensity Pro or the Matrox MX02 Mini?
I prefer the MX02 Mini, but I have read here that it is not supported and I can't use Prospect with it? Is there any change on this? (Videoguys packages NeoScene with the MX02 Mini, but why if it is not compatible with cineform?)
(I also need analog capture, but I think both options support this.)
Old August 5th, 2009, 12:52 PM   #2
Unfortunately the Mini won't encode in Cineform, but Matrox is looking at that possibility -- they told me. For now, it can only use their Matrox codec, or uncompressed. The Matrox codec is pretty good actually, and it works well with Premiere. Problems arise only when you want to use the codec with Vegas...
Eugenia Loli-Queru is offline   Reply With Quote
Old August 5th, 2009, 01:57 PM   #3
Thank you.
But if I do not want to encode Cineform, I only want to monitor a Cineform timeline in CS3. Do I understand correctly that it still will not do this either?
I just need to see what the colors look like on an external consumer HDMI monitor. Thanks, again.
Old August 9th, 2009, 08:23 AM   #4
To my knowledge, Cineform recommends Xena LHe for playback to external monitors:
AJA | Xena-LHe 12-Bit HD/SD Video Capture & | XENA LHE | B&H
Or the latest Xena LHi:
AJA | XENA LHi Capture Card (Windows) | XENA LHI | B&H Photo
The latter seems to have HDMI I/O.
Alex Raskin is offline   Reply
