After Effects CS4 Question at DVinfo.net
CineForm Software Showcase
Old July 26th, 2009, 06:25 AM   #1
I just installed After Effects CS4. I do not have cineform as option under export file types. Am I missing something?
Tim Bickford
Tim Bickford is offline   Reply With Quote
Old July 26th, 2009, 10:10 AM   #2
Have you checked it under Video for Windows /Format Options?
Alex Artem is offline   Reply With Quote
Old July 26th, 2009, 10:25 AM   #3
CTO, CineForm Inc.
For Neo Scene the AE is only under Video for Windows. For Neo HD or better you get eh CineForm AVI export mode. If you don't see either, reinstall your CineForm product, if that doesn't work contact support.
Old July 26th, 2009, 12:47 PM   #4
I will check it out.
Tim Bickford
Old July 28th, 2009, 05:13 AM   #5
David, are the resulting files the same with either option?
Paul Cascio
www.pictureframingschool.com
Paul Cascio is offline   Reply With Quote
Old July 28th, 2009, 08:55 AM   #6
CTO, CineForm Inc.
VfW is an 8-bit API, for 16-bit support we had the export to the higher end products. With you have finished your color correct on output from AE you will not notice the difference.
