RAW vs FilmScan
Is there an advantage to record in RAW vs FilmScan?
I've built (yet another! what is it, the 5th?) PC that captures HD-SDI 1080p24 into Cineform FilmScan. Say, SI-2K utilizes Cineform RAW instead. Should I be looking that way, too? Why? (BTW, I currently have Prospect HD 3.4.0 and it seems to be able to read RAW files from SI-2K web site's samples section.) |
CTO, CineForm Inc.
Those or not the same concept. RAW is like 422 is to 444, Filmscan is quality setting. The SI-2K encodes RAW formatting in Filmscan 1 or 2 quality. If you don't have a CFA Bayer RAW sensor source, you don;t need RAW encoding. CineForm RAW is for SI-2K, ARRI D21, Dalsa, Phantom and Red.
David Newman -- web: www.gopro.com blog: cineform.blogspot.com -- twitter: twitter.com/David_Newman |
Did you just say Red?
So now there is a native Cineform workflow while acquiring image in RED? That would change the game for me... I was reluctant to look at the new Scarlet/Epic with FF35 sensors because I'd rather stick with the Cineform workflow and these cams dont seem to support taht natively? |
1. David, any specific settings that you would recommend with this setup?
I usually set the cam to output 24PsF via HD-SDI - so HDLink would not have to waste processor cycles removing 3:2 pulldown from the 60i signal. 2. Currently I'm capturing in FilmScan. Should I change to FilmScan2 ? What would be the benefit of that vs file size increase if any? 3. I do not see any additional controls in HDLink except for the quality setting like High vs FilmScan etc. Does it automatically capture in 444 when i choose FilmScan? Thanks! |
#5 |
CTO, CineForm Inc.
We use the RED SDK and transcode to CineForm RAW (or 444 or 422) as needed. Yes it would be 10X easier to post it if was CineForm native, but you can batch your conversions.
1. Yes that is best. 2. Filmscan is fine, that is what I use for everything (or High if my outputs are down res'd.) Filmscan 2 is just for the extra paranoid. 3. HDLink is 4:2:2 single link only. For 444 captures, you need a 444 source (Genesis, F23, Viper, etc) and dual link HDSDI (Xena 2Ke) and a tool like CineDDR. Filmscan is just a quality setting, so we have 422 Filmscan and 444 Filmscan. The quality setting go it name from scanning projects that converts DPX source to CineForm.
#6 |
I'm sure this is a very basic thing, but would you kindly explain further please...
I do understand that the incoming signal is 422 as fed in by the HD-SDI single link. (And it looks like it is 10bit coming out of EX1). Now, when I tell HDLink to capture into FilmScan... that resulting AVI file... is it 10-bit 444 (but actually filled with 422 color info), or not? Sorry if this sounds silly. |
#7 |
CTO, CineForm Inc.
Not. It is a 10-bit 4:2:2 AVI, there is no value to up convert to 4:4:4 RGB at that encoding stage. Also Prospect HD doesn't support 4:4:4 encoding (need 4K for that.) The reason to use 4:4:4, is for keying from 4:4:4 sources, film or ever expensive cameras, or other heavy effects work. Most of the time 4:2:2 is plenty for a source encode, even within a 4:4:4 composite.
#8 |
Thanks David!
Hey, enjoy your 3D joystick man ;) I'm on Twitter too now. |
