How do you regard First Light? at DVinfo.net
CineForm Software Showcase
Old July 14th, 2009, 01:38 PM   #1
Probably a dumb question, but one that I'm not clear on.
What is First Light intended to do? Can one regard it as a color corrector or is it used to just set some basic light settings with actual color correction to come later in the workflow?
Mike Falconer is offline   Reply With Quote
Old July 14th, 2009, 03:03 PM   #2
CTO, CineForm Inc.
It is called "First Light" for a reason, as it is primarily design to correct image issues before an NLE messes things up, and final color tweaks are applied on top of the First Light changes. However, there are many using it for final grading. Totally up to you.
Old July 14th, 2009, 05:16 PM   #3
Just started playing with it. Pretty cool program. Any chance we'll be seeing scopes in future versions?
Thanks, Marc
Marc Salvatore is offline   Reply With Quote
Old July 14th, 2009, 05:44 PM   #4
CTO, CineForm Inc.
Yes, but histograms are going in first.
Old July 14th, 2009, 06:54 PM   #5
Great, thanks.
Old July 15th, 2009, 12:44 AM   #6
concept is very nice though it is in early stages. i used it for a 3 hr final output project and it worked a treat. Rendering took a long time though but it could be just the early stage cineform was with cs4 which contributed to the long rendering.
I would like to see in no particular order:
1. Scopes
2. Integration with CS4 so i dont have to launch seperate application
3. Secondary color correction
Anish Sharma is offline   Reply
