Neo Scene- no audio in Vegas 9 Pro but OK in CS4?? at DVinfo.net
CineForm Software Showcase
Old July 11th, 2009, 12:53 AM   #1
When I drag my Neo Scene AVIs (made from an AVCHD source) onto the timeline, I see no audio track in Vegas. Under properties it states "audio attributes cannot be determined".
However these same files import into Premiere Cs4 without issue, audio track looks fine. Double checked in VLC player and no issue there either.
And even stranger, the Neo Scene AVIs made from my HDV source (Canon HV20), look fine in Vegas. It only seems to be AVIs made from my Pana HMC150 .mts files and only in Vegas.
I have build 119 (fresh re-install) and the AC3 filter installed. Figured I would double check to see if I am missing something before opening a TT.
Ed
Ed Kishel is offline   Reply With Quote
Old July 11th, 2009, 08:56 AM   #2
CTO, CineForm Inc.
I believe this has come up before, support may no what the answer is.
Old July 11th, 2009, 11:15 AM   #3
I opened a trouble ticket. Its weird becuase I had no issue when I was using build 112. The only thing that has changed since then is that I upgraded my audio card (I needed asio support for my DAW).
Old July 14th, 2009, 03:28 PM   #4
no answer from support yet, but I did figure out a fix- reinstall AC3 filter. I am guessing when they get around to my issue it is what they will suggest.
Old July 14th, 2009, 03:32 PM   #5
CTO, CineForm Inc.
Please follow up with support that you have a solution, helps speed up processing of other tickets.
Old July 14th, 2009, 04:14 PM   #6
I actually did close it earlier and notated my resolution (incase it comes up again with someone else)
