Prospect 4K & Windows 7 at DVinfo.net
CineForm Software Showcase
Old July 9th, 2009, 04:41 PM   #1
It sounds like Prospect 4K is Windows 7 friendly. What pitfalls would be in store if I utilized it as a trial for bit, then revert back to Prospect HD (hopefully within the trial period) when the Win 7 details are ironed out?
So long as I don't create anything outside of Prospect HD's capabilities, I should be able transition between the two?
Any caveats with installing an uninstalling back and forth?
Finally... which version of Prospect 4K is now working with Win 7, and is it working with CS4, or only CS3?
Marty Baggen is offline   Reply With Quote
Old July 9th, 2009, 04:57 PM   #2
CTO, CineForm Inc.
Both P4K and PHD are not Window 7 ready for the CS3 playback engine is not yet compatible, but under CS4 both work. There is no need to switch between PHD and P4K unless you want the higher end features.
Old July 9th, 2009, 05:33 PM   #3
Please clarify.... are you saying PHD works with CS4 on a non-Win 7 OS? Or that PHD works only in Win 7 with CS4?
I'm getting green flashed video with PHD/CS4/Win 7.
Old July 9th, 2009, 06:28 PM   #4
CTO, CineForm Inc.
Support has a fix, yet the new build has it too, out tomorrow if all goes well. Still a minor release, yet it has lots of cool stuff and bug fixes.
Old July 9th, 2009, 06:33 PM   #5
Fantastic.
Will you guys please pool your money and buy out Adobe!
