Neoscene 24p conversion improvement. at DVinfo.net
CineForm Software Showcase
Old June 29th, 2009, 07:43 PM   #1
I have heard that 24p conversion within Neoscene will be improved.
Can anyone verify if this is the case, and when?
Jacob Mason is offline   Reply With Quote
Old June 29th, 2009, 09:41 PM   #2
CTO, CineForm Inc.
It is near perfect if your start with 24p in 60i with pulldown, that is what the 24p mode is designed to do -- nothing else has been suggested.
Old June 29th, 2009, 10:21 PM   #3
The Literature I read when buying the product:
Neo Scene also extracts progressive frames from your footage to allow 24p or 25p editing, regardless of whether your footage was shot in progressive or interlace mode.
All I was interested in finding out was if there were improvements that could be made in the way it processes the 5DmkII's 30p to 24p.
Because for now, it has some heavy ghosting/bluring.
Old June 29th, 2009, 10:26 PM   #4
Neo Scene does excellent telecine removal, which is the extraction of 24p from 60i, and is what the text you quote refers to. Converting into 24p from 30p is not the same thing, nor is it supported by Neo Scene. We were confused by your question. It is not about improving 24p support - the question is whether we'll support conversion into 24p from 30p. Currently we have no plans to do this. As you've experienced, the conversion technically works but it is not intended for this purpose.
You might experiment with After Effects which works for this purpose but is pretty slow.
David Taylor is offline   Reply With Quote
Old June 29th, 2009, 10:40 PM   #5
Thank you.
I will still use Neoscene to get more manageable files for editing, I was just confused by the 24p option.
Now I understand.
Old July 6th, 2009, 12:33 PM   #6
Are any Cineform products suitable for doing the 30p to 24p conversion off of the 5DM2?
Per Farny is offline   Reply With Quote
Old July 6th, 2009, 12:42 PM   #7
CTO, CineForm Inc.
30p to 24p is not a simple conversion operation, requires pixel motion prediction, and even that gets it wrong sometimes. Not something for a fast prosumer conversion tool. Convert with Neo Scene to 29.97p, then use AE Timewarp or Twixtor to produce 23.976/24p.
Old July 6th, 2009, 12:49 PM   #8
Sounds good. Thanks!
Old July 15th, 2009, 01:27 PM   #9
OT sort of but is it possible to convert 50i to 24p with Neo Scene? If so can someone point me in the right direction?
David Dwyer is offline   Reply
