Digitizing with inferior HDV camera = ??? at DVinfo.net
CineForm Software Showcase
Old June 17th, 2009, 10:43 AM   #1
Hello,
If I digitize footage shoot with HDV camera sony z1u and I use an inferior (cheaper to rent) hdv sony camera to import footage in ProspectHD; will quality be less then if I use the Z1U or same ?
Also, is there a list of camera that HDlink doesn't work with ?
Thank you.
Frederic Leclair is offline   Reply With Quote
Old June 17th, 2009, 02:00 PM   #2
If it's HDV, no matter how it was shot, it's already digitized. What you are doing, I think, is just capturing, and for that any Sony HDV deck will do just fine. I believe the deck mechanisms are all the same.
Old June 17th, 2009, 03:38 PM   #3
Ya capturing, sorry did a "Frenchism"...
so any deck or camera will do as long as it's HDV a can stream to computer as such.
Old June 17th, 2009, 06:15 PM   #4
We do it all the time with a little Sony A1. Makes for a fairly cheap "deck" for transferring all those captures from other HDV cams.
http://lightinaction.org
"All in the view of the LION"
Stephen Armour is offline   Reply
