2 activation for ProspectHD ???
I heard that ProspectHD license can be activated on 2 different computer (laptop & destop)...Is this true?
If so how to do this? Do I request another activation # via cineform's site or used the same one I already use ? Thank you. |
CTO, CineForm Inc.
It is true, just request another activation, just like the first.
David Newman -- web: www.gopro.com blog: cineform.blogspot.com -- twitter: twitter.com/David_Newman |
David, I have a situation where I allways keep Cineform on my main workstation...
and I also have another workstation that has the second Cineform activation but its not used as much as the main... and the question is... can I add a third activation for a lap top... one that I dont use a lot but would be nice to have an activation on it when I use it instead of the second work station...... so can I have an activation on my main computer and it stays put... and then be able to have two activations that I can switch between the hardly used workstation and the hardly used laptop... to me its the same as having two setups... just depends on when I need to go portable... so I'm thinking, swap installs from the work staion to the laptop when needed and keep the install on the main workstation... can this be done?? |
CTO, CineForm Inc.
Ray, yes the latter will work. Deactivate the older workstation then request a activation for the laptop, the license will be transferred.
#5 |
Is this also the case for Neo4K (mac) ? Or does it only apply to Prospect?
#6 |
CTO, CineForm Inc.
I believe you can install on laptop and a workstation on the Mac also, but the license transfers are handled differently (not automated.) If a second activation doesn't work on the Mac, please send question into support.
#7 |
Thank you David.
