Need to Upgrade for 5d2? at DVinfo.net
CineForm Software Showcase
Old June 2nd, 2009, 10:22 AM   #1
I've been using Neo HDV ver. 3.xxx. Most recent Neo HDV update (discontinued) only takes HDLink to ver 3.xxx, and it looks like I need to upgrade to Neo Scene to capture 5dII files with HDLink 4.x. I guess there is no cross-grade deal and will have to pay the $129. Assuming Neo Scene will also support HDV, or is there a better way to go.
Using Vegas 8.0d with XLH1 and HV30
Any advice appreciated.
C100, 5DMk2, FCPX
Old June 2nd, 2009, 10:33 AM   #2
Ken:
That is what I had to do. Seems like there was some kind of cross grade deal initially. But you can buy NeoScene at VideoGuys.com for about $100.00.
By the way, I keep NeoHDV ready to go, because I like to resize occasionally, and NeoScene does not give that capability. You cannot have both installed at same time, but you can deinstall and reinstall without losing your registration key. A bit of a hassle, but worth it if you have to get back the NeoHDV for some reason.
Chris J. Barcellos
Old June 2nd, 2009, 12:46 PM   #3
CTO, CineForm Inc.
From NEO HDV you can cross grade to Neo Scene for $69 or upgrade to NEO HD for $250. Getting the First Light application for only $250 is the way to go.
Old June 2nd, 2009, 03:35 PM   #4
Thanks guys - I'll dig a deeper into th Cineform site before deciding between Neo Scene & Neo HD
C100, 5DMk2, FCPX
Old June 2nd, 2009, 04:37 PM   #5
CTO, CineForm Inc.
Best way to go it to try them both.
