HDLink Feature Request at DVinfo.net
CineForm Software Showcase
Old May 9th, 2009, 08:19 AM   #1
This is really annoying and finally annoying enough to warrant a post (at least, in my mind). I'm constantly opening Prefs to change the output directory. Why don't you just put an output directory entry field on the main application? I don't change anything else in Prefs (I capture with HDVSplit when coming from tape, but usually record to a Firestore, so the base capture name doesn't really change often).
I've never understood why something that is as volatile as the output directory is in a prefs dialog....
Matt
Matt Vanecek is offline   Reply With Quote
Old May 9th, 2009, 01:43 PM   #2
I second the suggestion. Should be done in some other programs, too.
Old May 9th, 2009, 01:50 PM   #3
Absolutely.
When working on multiple projects it's too easy to output to the wrong folder because "forgot" to check the prefs dialog.
Bob
Old May 10th, 2009, 12:02 AM   #4
I agree.
Julian
Julian Frost is offline   Reply With Quote
Old May 10th, 2009, 01:03 AM   #5
Same here!
http://www.mlotv.com
Gary Brun is offline   Reply With Quote
Old May 10th, 2009, 01:49 AM   #6
actually, every thing should be on opening page, so you won't forget settings
Chris J. Barcellos
Old May 10th, 2009, 08:16 PM   #7
I change my vote... I want Chris's suggestion. Put it all on the front screen. There's no real need for a Prefs page.
Julian
Old May 10th, 2009, 08:39 PM   #8
I could handle it all being on the front page! Going to the prefs dialog is just a usability obstacle, in my opinion. Lay it ALL out there, so I won't be wondering why they heck my hiqh-quality CFHD is in folder X on drive Y instead of where I expected it to be! the software could really help us to not worry about those niggling little details!
Matt
Old May 11th, 2009, 11:44 AM   #9
HDLink, unfortunately, is long overdue for an overhaul. Originally intended only for HDV capture and conversion, it's clearly matured into something far more expansive and powerful.
I'm hoping to be able to give HDLink the makeover it deserves at some point later this year.
At that time -- just like we did with First Light -- we'll take some user suggestions into creating the UI.
Thanks for the comments!
Tim Bucklin
CineForm Software Engineer
Tim Bucklin is offline   Reply
