One last 4.0 beta. - Page 13 at DVinfo.net
CineForm Software Showcase
Old May 10th, 2009, 06:17 AM   #181
Cameron,
Maybe it's an OS thing, but I actually get two crashes. First ImporterProcessServer crashes. That's the crash report I posted. Second Premiere hangs (it's waiting for ImporterProcessServer to respond). That looks like the crash report you posted.
Do you get a crash report for ImporterProcessServer?
Regards,
Glenn
Glenn Babcock is offline   Reply With Quote
Old May 10th, 2009, 06:32 AM   #182
Ok here is what I am trying now!! unfourtnatly I will not be home to see the outcome I have to leave in a few minuets and wont be back until 5. I did a system search for
IPPMPEGDecoder.dll
I found this in PP, ENCORE,Adobemedia encoder ect. What I did id take the one from PPCS4 and put in in Adobe media encoder folder over writing the one thats in ther now. Re booted and started.
export/media and Cinaform.avi 720x480. its been processing for over a hour now and no crashs I would have had one 30 min ago by now. I think it the AME not PPcs4
location of IPPMPEGDecoder.dll is x86/programliles adobe then what ever program like Premier Pro CS4
Encore CS4
I forgot to mention the system seems to be running very stable CPU abot 60% and ram about 50%
Last edited by Bruce Gruber; May 10th, 2009 at 06:36 AM. Reason: forgot to mention
Bruce Gruber is offline   Reply With Quote
Old May 10th, 2009, 06:37 AM   #183
Glenn, yes that is what I just posted.
Also, can anyone confirm that these are right for the Adobe Common Plug-in's folder:
CFHD_AVI_Importer
CFHD_File_Exporter
CFHD_MOV_Importer
CFRenderProc
Last edited by Cameron Smeal; May 10th, 2009 at 06:40 AM. Reason: Additional question
Cameron Smeal is offline   Reply With Quote
Old May 10th, 2009, 07:16 AM   #184
Call me crazy but just for fun I thought I would try pushing the raw .mt2 files around without any CF. Result - around 30 mins of pure editing joy at full 1080/25p, several transitions and effects, minimal rendering required, CPU at around 35% and RAM at 45%. No ImporterProcessServer crashes, no hangs, no problems. CS4 just screams along.
Tell me again why I've spent nearly 2 weeks out of action with CF or is that the dumbest statement this post has seen?
Old May 10th, 2009, 08:56 AM   #185
Hi Camron
Was that file captured with cf? Or is it captured thru pp?
Bruce
Old May 10th, 2009, 10:06 AM   #186
I've tried editing projects that didn't have any CF files in them, just HDV captured with Premiere and AVCHD files, PP4 runs like I uninstalled ProspectHD. About the same thing either way though, I still can't use CF.
I'm getting decent performance editing HD without CF as long as I don't mess around too much with effects. I can put three HD tracks into a multi-camera edit and it's real time. But where I was really looking at CF was for color correction.
CF has me spoiled already with the ability to apply color correction and preview it in real/near-real time, either with FirstLight or using PP CF color effects. I'm also impressed with the quality of the CF color correction. But I can't get through a workflow with it. :-(
Regards,
Glenn
Old May 10th, 2009, 04:17 PM   #187
Bruce - these were captured with PP. I've tried both clips from Compact Flash (I use an HVR-Z7P) and clips injected from tape. Taking CF out of the picture my system screams along merrily.
Glenn - Same result here. I haven't tried too many effects (that will be the next test). I'm with you in that I was looking to CF for maintaining a format and quality through the workflow, as well as being able to colour correct, break-out all my clips from tape into a nice package. The apparent performance gain was going to be a bonus really, and something to delay buying a new quad core or having to go down the Matrox route.
So far though, all CF has given me is a headache, system instability and real loss of productivity. My Proavio RAID 5 array has rebuilt itself 3 times now since installing CF and without it, it is now rock solid.
Guys, I really feel like I am missing the point here in a big way. This thread seems to have gone quite quiet too and it appears it's just us new boots struggling to find an answer.
Or it it just me....? Can either of you tell me if editing MPEG is really that bad if performance seems fine? I am losing quality doing this?
Old May 10th, 2009, 08:34 PM   #188
Cameron,
M2T was not intended to be a pro editing format. Perhaps it works well enough for hobbyists. And with hardware/software advances, and a little patience for rendering effects, most modern NLEs can handle editing M2T. But it's not an editing format.
Most of us are providing feedback and biding time, because we know the reputation and history of Cineform vs. Adobe. We are fully confident that Cineform will be able to adapt to the CS4 mess (really, you just DON'T change programming APIs without providing a compatibility layer!! That's just idiotic!). Patience is the key, and having a workflow that allows you to get work done in a reasonable manner while at the same time providing feedback to Cineform. If you have time-critical items, then you're probably better off editing in CS3/before, or not using Cineform (if you have CS4) until CS4 has been stabilized.
Matt
Matt Vanecek is offline   Reply With Quote
Old May 10th, 2009, 08:44 PM   #189
Matt, thank you for a great, straight answer. Apologies if these questions are stupid, but that is why I am on this forum - to learn from others and to contribute when I can.
This is largely what I thought, though can I ask if there is a degradation in quality when moving MPEG around?
Old May 11th, 2009, 12:50 AM   #190
Hello Cameron
I also use Mainconcept's Mpeg Pro Hd which does a very good with mt2 files. Infact comparing a first generation render with Cineform using some color correction ( Colorista- Magic Bullet) etc, to me it seems sharper.
It is not yet available for PPCS4
Gil
Gil Reitsma is offline   Reply With Quote
Old May 11th, 2009, 03:05 AM   #191
IPPMPEGDecoder.dll
Encore CS4
Ok my resaults:
this did process all the way!!! the exact same timeline that would not allow me to export before without getting importprocess error, before I swaped IPPMPEGDecoder.dll...... this was a 50 min timeline. But now the disapointing resaults. Encore would crash 2min into transcosding ( again I am trying to output to mpeg-2DVD) again I need to output to both BD and DVD mostly DVD right now!
Old May 11th, 2009, 03:16 AM   #192
Hi Cameron thanks, I was just curious. I would expect that PP would scream along with the standard file. and I agree CF files are not running correctly right now. I susupect that part of the speed issue is that they do not have their excelerator operating in CS4.
Trust me when it comes to their compressor it is the best that I have found and Demoed? But the bigger underlying problem is what its the problem with the importer server crash is all about?
Old May 11th, 2009, 04:06 PM   #193
Thanks Gil. I've been looking at Mainconcept too, but as you note, it seems we are all waiting for CS4.
Bruce - Yes, until the importer server crash issue is sorted out, I certainly can't have CF in my workflow unfortunately.
Any Cineform people out there with an update?
Old May 11th, 2009, 04:19 PM   #194
Fixing the CS4-PPro issues are our highest priority. We're working hard on it, but we haven't had new information to report yet. Stay tuned....
David Taylor is offline   Reply With Quote
Old May 11th, 2009, 04:26 PM   #195
Thanks Dave!
I am trying build 209? I did not notice a new build was posted Friday. I ununstalled CS4 and re unstalled before I installed 209 build! I am giving it a go again!! Luckly I have a brand new computer and no time critical projects for antoher 2 weeks. If need be I will do another fresh install of Visat/64 because I have nothing else on my pc at the moment.
