Rendering to CF avi's in Premiere CS4 at DVinfo.net
CineForm Software Showcase
Old April 12th, 2009, 04:37 AM   #1
Whatever setting i choose in the CF codec (NeoScene) the avi (1440x1080) turns black after a few seconds.
Sometimes i get lucky and it does the whole sequence (Dec: rgb. Enc:ITU, High HD, interlaced).
By the way what are the best settings.
Old April 12th, 2009, 02:32 PM   #2
I am having the same problem. I import converted Cineform files, edit, trim etc no problem. Vers 1.2 works good.
I then want to export my entire timeline as one CF AVI file for archiving etc. I use export>media>Microsoft AVI>Video>CineForm HD Coded 4.x
I found that if the exported file is UNDER 2gigabytes, it works ok. If the exported file is over 2gb, it does not play correctly in premiere. I noiced it does not show that the file has any audio if it is over 2gb in size.
I am on Vista x64 8mb Ram, Premiere CS4 4.0.1, NeoScene 1.2
Andy Urtusuastegui is offline   Reply With Quote
Old April 12th, 2009, 06:54 PM   #3
CTO, CineForm Inc.
Adobe VFW AVI exporters are limited to 2GB, it is a long exiting Adobe bug/limitation.
Old April 13th, 2009, 01:39 PM   #4
Do you have an answer for my question because my avi's are smaller than 2 gig?
Never mind i solved it. Added a Magic Bullet filter, rendered the whole timeline to a CF avi, 3,3 gig, no black.
Old April 13th, 2009, 02:00 PM   #5
CTO, CineForm Inc.
Contact support. Andy above and myself can confirm that under 2GB should be working fine.
Old April 13th, 2009, 08:18 PM   #6
Ann, are you saying you exported a 3.3gb file and it play ok, with sound and video in Premiere?
Old April 13th, 2009, 11:04 PM   #7
Which filter?
Charles W. Hull is offline   Reply With Quote
Old April 14th, 2009, 03:31 AM   #8
Yes i rendered an over 5 minute 3.3 gig large CF avi with stereo audio and no black parts. Plays perfectly in the timeline.
Nested the timeline and added just the Vignette from Magic Bullet Looks.
Tried Fast Blur (no tweak) in Premiere (we used to do that in Premiere 6.5 for some reason) but that did not work.
So i believe MB adds something that gets the avi proberly rendered, besides i do not believe there is a 2 gig limitation on Adobes VFW.
Old April 14th, 2009, 12:55 PM   #9
Just did another test: 10 minutes timeline with MB and audio rendered to a 7.7 gig CF avi. Runs perfectly. Without MB its black.
Old April 14th, 2009, 03:49 PM   #10
Ann, if I understand, if you try to export the timeline as a CF avi, and do not add any magic bullet effects, then the CF avi does NOT play correctly.
Also, what Product of MB do you have? I see they have different ones.
Old April 14th, 2009, 05:07 PM   #11
Yes that is what i am saying, it sounds weird but that is what i am experiencing.
Magic Bullet Looks 1.2.
Ann Bens is offline   Reply
