What's your Hardware Setup (Speedgrade config) at DVinfo.net
CineForm Software Showcase
Old April 10th, 2009, 07:53 AM   #1
Hello,
Could you help me out with putting together a system that will meet the requirements for speedgrade? I am curious what is in the system that you guys are using. I have attached the quote that I've put together, though I might have a few components that are unnecessary and I could save some $$. Thanks for your advice! And keep up the great work!
Okay, getting closer to finalizing this. Here is an updated list of the hardware suggested for a system. Quoting around $7000 CDN. Some parts may or may not be necessary (could upgrade or downgrade).
Feeback is greatly appreciated so I get a compatible system.
Primary function will be running cineform raw si2k footage. Possibility of expanding to work on r3d and 12 bit uncompressed.
Justin
8mm.16mm.transfers//cinematography
3200a Yonge St. Toronto, ON. M4N 2L1
416.803.1101
Frame Discreet - regular 8mm, super 16mm, super 8mm, film transfers to dvd toronto
FrameDiscreet.com <br> transfers // cinematography for the latest!
Please review the following list of specs for a newly configured system. This time I have 64-bit XP pro OS… This can be switched with XP PRO 32, but then max ram will be limited to only 4GB. This raid controller is not onboard, and I subbed the 4600 vid card with the 5600…
CORE 2 QUAD Q9400 C4 2.66GHZ 775 RET
775 V X16 4D2 GL R A
2GB DDR2 800 PC6400
TOTAL 4GB
1TB SATA2 7200RPM 32MB RAID EDITION
TOTAL (4) 1TB HARD DRIVES
RAID 5 ARRAY (STRIPED WITH PARITY)
SERIAL ATA 300 RAID CONTROLLER ONBOARD
BLU-RAY/DVD COMBO 16X LS BLACK BULK
QUADRO FX5600 1500D3 X16 2DVI R
ONBOARD SOUND
10/100/1000 GIGABIT NETWORK ONBOARD
SERVER TOWER BLACK
4XSATA HOTSWAPCAGE SR105
600W POWER SUPPLY
DELUXE 250 USB KEYBOARD BLACK
OPTICAL USB MOUSE BLACK
WINDOWS XP PROFESSIONAL 64 BIT (DVD)
Justin Lovell is offline   Reply With Quote
Old April 10th, 2009, 09:22 AM   #2
CTO, CineForm Inc.
If you haven't purchased, get an i7.
Old April 10th, 2009, 12:33 PM   #3
I just recently bought an i7 920 with 12gig 1600 DDRIII ram and a Quadro card... it flies on vista ultimate. Just cant wait for the Cineform CS4 version :-)
http://www.mlotv.com
Gary Brun is offline   Reply With Quote
Old April 10th, 2009, 02:35 PM   #4
I just built an i7 920 sytem with 6GB DDR3. Operating system is Vista 64 (Home Premium, I think).
It runs very well. I do not have a Quadro card, just a GTX260.
I am not an expert and know little about video cards. However, it's possible you don't need the $3000 video card, depending on the specific applications you are running and the processes that need to be carried out and the precise workflow you are following. A $500 card may be fine--but, again, it depends on the specific applications and work flow.
To know for sure, it's necessary to get info from an expert on the applications you are running.
(The ASUS P6T series of i7 motherboards are excellent and have received thumbs up pretty much across the board.)
Old April 10th, 2009, 04:10 PM   #5
I am on the ASUS P6T SE motherboard.
Find a bottle neck though with the firewire 400.
Thinking about getting a 800 card for my WD Studio drives and also I use a RME fireface 800 as I dabble a bit in music production.
Went for the quadro card because I have now 4 hdmi out.
This feeds my two 24" ASUS monitors and my Samsung 32"LCD so the monitoring is excellent.
The i7 handles the HD files real well.
