New Premeire CS4 Beta importer. at DVinfo.net
CineForm Software Showcase
Old March 24th, 2009, 10:45 AM   #1
CTO, CineForm Inc.
I posted this info yesterday in the existing thread, and no one commented. Need feedback see we can formally release these components.
See post : http://www.dvinfo.net/conf/1032351-post69.html
Old March 24th, 2009, 05:02 PM   #2
Yay!
Not too much to say except, it works in both Premiere CS4 and now AE CS4 (!) Again, I'm running under Vista x64, so the DLL is installed in the SysWOW64 folder, not system32. Both MOV and AVI imports work. A small number of AVI files had a wowing effect in the audio, but I couldn't see what was different about those specific files. All files were captured or converted to CFHD with HDLink from NEO HD.
But, previewing is much slower than in CS3, almost unusable. That's an Adobe/Windows issue. Render the work area and it plays RT.
Jay Bloomfield is offline   Reply With Quote
Old March 24th, 2009, 06:33 PM   #3
It "works". It's really slow and choppy. Rendering out a 4 minute clip seems to be taking a while--17 minutes or so. Not sure why I need to render, though, but we'll see how it plays after that. Thought the whole point of CF was to enable RT play with no rendering....
Adobe should know, you never rewrite a public API, especially from one release to the next. You always refactor, so you don't break applications. Stupid Adobe...
Anyhow, without rendering the CF AVI, the playback is real jumpy and stuttered, it seems. Still, it's better than playing an unrendered M2T with effects applied...
Matt Vanecek is offline   Reply With Quote
Old March 24th, 2009, 10:38 PM   #4
The Good, The Bad, The Ugly
Good: The playback is smoother and uses less CPU than before. Thanks.
Bad: Memory leak is still there. Before I would use up my 4gb in abot 1 min 15sec. Now it takes about 2:15 seconds before all memory use up and machine becomes unresponsive.
Ugly: I tried on of my Cineform clips I made last year with CS3 with the Cineform movie export feature. The clip had slow motion in it. When playing this clip, the sound playback was bad. It sounded like a record skipping. These same clips play fine in CS3 with NeoHD build 193.
Vista x64 SP1, 4GB Ram
CFHDDecoder.dll file vers 2.2.0.25 Product ver 3.4.8.192
CFHD_AVI_Importe.prm 241,664 bytes
I will submit another bug report
Andy Urtusuastegui is offline   Reply With Quote
Old March 24th, 2009, 10:43 PM   #5
[/url]
Does not play Cineform files smoothly with CS4, whereas the first beta did play smoothly. I have reinstalled the first beta.
XP, Q6600, 4GB
Charles W. Hull is offline   Reply With Quote
Old March 24th, 2009, 10:48 PM   #6
CTO, CineForm Inc.
Andy,
No duplicate posts please. (MOD: copy in other thread removed)
Charles,
speed hase not changed for the worse, as Andy reports it might be a tad faster, it certainly it fixes bugs that will not be unfixed, so going backwards will not help you or us with this beta testing. Set the playback mode to auotmatic or draft.
Old March 25th, 2009, 09:38 AM   #7
Andy,
Charles,
David, here was my test. I am doing some re-editing of a long video so I brought one of the MOV clips into a new sequence in CS4 after I had installed the new beta, trimmed and edited and rendered the clip, and exported it with the Cineform HD Codec. When I brought this clip back into the video sequence it would not play smoothly. I re-installed the original beta and repeated these steps and the clip played smoothly. In each case the playback mode was automatic.
I can repeat this test this evening, or perhaps some other test you suggest, but request you take another look at whether the playback speed has decreased a little.
Old March 25th, 2009, 11:26 AM   #8
CTO, CineForm Inc.
Why are using Premiere to convert your source? Convert in HDLink and use the same source in both. Anyway, the importer is design from full compatibility, we can't go back on that, it Premiere is that is slow, we will be fixing that with our Real-Time playback engine when it is moved from CS3.
Old March 25th, 2009, 01:04 PM   #9
I'm using the Mercalli plug-in and it doesn't work with trimmed clips in CS4, so I use CS4 for trimming and then export the clips and import them into the video sequence. I'll try HDLink on some raw MOV clips and check how well they play.
Sure, I'll move to the real-time engine when it's ready - just reporting what I see.
Old March 25th, 2009, 07:59 PM   #10
I converted four clips with HD Link and loaded them to a CS4 time line to compare the new beta to the older beta. All of the clips played smoothly with both beta versions.
Old March 25th, 2009, 08:59 PM   #11
for now i can see all of my clips, they dont just stop with black suddenly on the timeline. its nice to know april might bring a rt player to premiere, i just got a vertex 120gb ssd to put as my premiere cache drive as of tonight, so with these preview files i look forward to see the difference from the previous velociraptor dedicated to premiere cache and cineform preview files
Gary Greenwald is offline   Reply
