Problem transcoding Cineform to DPX using cf2dpx at DVinfo.net
CineForm Software Showcase
Old March 4th, 2009, 05:07 PM   #1
I've tried exporting a 4197 frames long CFHD avi file with cf2dpx using this command line:
cf2dpx Y:\DPX\CFDPX\TRAILERDPX.dpx 0 Y:\DPX\TRAILERCFTODPX.avi
The problme is that the converter transcoded and replaced 4197 times the same file name with no added number and I ended up with only 1 TRAILERDPX.dpx file size of 7K.
I've transcoded with After Effects 7.0 with Cinenon DPX and had correct transfert of about 27 GB final size.
What did I do wrong with cf2dpx and which is better the After Effect or Cineform DPX ?
Thank you.
Frederic Leclair is offline   Reply With Quote
Old March 4th, 2009, 05:20 PM   #2
CTO, CineForm Inc.
type cf2dpx alson on a shell and it will tell you how to use it. Here is the help you get
Usage: cf2dpx source.avi|mov output_template.dpx [switches]
switches
-iX - input frame number X
-oX - output frame number X
-dX - duration, extract X frames
-bX - base frame count for the sequence (name = base + start)
version 1.40 18-February-09
example: cf2dpx M:/source.avi M:/sequence%05d.dpx -i134 -d24 -b10000
dpx naming: basename%0xd.dpx -- 'x' is number of digits the count
e.g. "seq%05d.dpx -b400" produces seq00400.dpx, seq00401.dpx, ...
"clip-%03d.dpx" produces clip-000.dpx, clip-001.dpx, ...
This is a newer verion than what you seem to be running, but in either case you didn't offer a naming template for your DPX outputs, you told it to put all the frames into one dpx file. You template should be Y:\DPX\CFDPX\TRAILERDPX_%05d.dpx -- this will get you TRAILERDPX_00000.dpx through TRAILERDPX_04196.dpx
Old March 6th, 2009, 09:10 AM   #3
thanks.
I run last build of AspectHD v5
