Problem transcoding Cineform to DPS using cf2dpx at DVinfo.net
CineForm Software Showcase
Old March 4th, 2009, 05:06 PM   #1
I've tried exporting a 4197 frames long CFHD avi file with cf2dpx using this command line:
cf2dpx Y:\DPX\CFDPX\TRAILERDPX.dpx 0 Y:\DPX\TRAILERCFTODPX.avi
The problme is that the converter transcoded and replaced 4197 times the same file name with no added number and I ended up with only 1 TRAILERDPX.dpx file size of 7K.
I've transcoded with After Effects 7.0 with Cinenon DPX and had correct transfert of about 27 GB final size.
What did I do wrong with cf2dpx and which is better the After Effect or Cineform DPX ?
Thank you.
Frederic Leclair is offline   Reply
