NeoScene: 720/60P video is accelerated 2x at DVinfo.net
CineForm Software Showcase
Old February 20th, 2009, 11:26 PM   #1
Hi,
This technology is new to me, so my problem may be due to my inexperience.
I used NeoScene (trial version) to convert a 720/60P AVCHD file.
The resulting Cineform file plays back the audio at the normal speed, but the video plays back at *twice* the original speed.
I used MediaInfo to compare the AVCHD and Cineform files (see below).
Note that the duration of the video in the Cineform file is *half* of what it is in the original AVCHD file.
What could be the cause of this issue?
Guy St-Denis
************* START MediaInfo output **********************
Media file information obtained with MediaInfo 0.7.10.BETA
ORIGINAL AVCHD FILE:
General
Complete name : G:\media\video\hmc150_01\sdhc-20090111T2152\PRIVATE\AVCHD\BDMV\STREAM\00000.MTS
Format : BDAV
Format/Info : BluRay Video
File size : 1.51 GiB
Duration : 10mn 53s
Overall bit rate : 19.9 Mbps
Maximum Overall bit rate : 24.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Duration : 10mn 52s
Bit rate : 18.7 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16/9
Frame rate : 59.940 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.339
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Duration : 10mn 53s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Video delay : -67ms
AFTER CONVERSION WITH NEOSCENE + AC3FILTER:
General
Complete name : L:\media\video\temp\00000-001.avi
Format : AVI
Format/Info : Audio Video Interleave
Format profile : OpenDML
File size : 3.78 GiB
Duration : 10mn 52s
Overall bit rate : 49.7 Mbps
Video
Format : CineForm HD
Codec ID : CFHD
Codec ID/Info : CineForm 10-bit Visually Perfect HD (Wavelet)
Duration : 5mn 26s
Bit rate : 96.0 Mbps
Height : 720 pixels
Bits/(Pixel*Frame) : 1.738
Stream size : 3.65 GiB (97%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Unsigned
Codec ID : 1
Codec ID/Hint : Microsoft
Duration : 10mn 52s
Bit rate : 1 536 Kbps
Resolution : 16 bits
Stream size : 120 MiB (3%)
Interleave, duration : 21 ms (1.28 video frame)
Interleave, preload duration : 2176 ms
************* END MediaInfo output **********************
Guy St-Denis is offline   Reply With Quote
Old February 21st, 2009, 10:07 AM   #2
CTO, CineForm Inc.
Need a sample of a source 60p file that does this.
Old February 22nd, 2009, 11:17 AM   #3
As mentioned before, I'm working my way through this new technology as well as learning the intricacies of HD and my new Panasonic HMC-150.
Here are my latest findings.
The HMC-150 has several recording formats, summarized as follows:
PH 1080/60i: 60 interlaced fields/s @ 21 Mbps
HA 1080/60i: 60 interlaced fields/s @ 17Mbps
HG 1080/60i: 60 interlaced fields/s @ 13Mbps
HE 1080/60i: 60 interlaced fields/s @ 6 Mbps
PH 1080/30P: 30 frames/s over 60 interlaced fields/s @ 21 Mbps
PH 1080/24P: 24 frames/s native @ 21 Mbps
PH 720/60P: 60 frames/s @ 21 Mbps
PH 720/30P: 30 frames/s over 60 frames/s @ 21 Mbps
PH 720/24P: 24 frames/s native @ 21 Mbps
After testing NeoScene with every format to reproduce the issue I described at the start of the thread, I found that only the "PH 720/30P" format produced the unexpected (to me) results of speeded-up video.
Contrary to my initial claims, the 720/60P format is *NOT* accelerated.
So, at this point I'm not sure if NeoScene would somehow be able to detect a 30P (over 60P) stream and generate a 30P file that plays back @ 30FPS instead of 60FPS as it seems to be doing now...
To be clear, I'm not saying this is a NeoScene bug, just wondering about options (technical or otherwise) to manage 30P (over 60P) footage.
Any comments or suggestions are appreciated.
Guy St-Denis
P.S.
This thread discusses this to some extent:
30p showing up as 59.94 frame rate - DVXuser.com -- The online community for filmmaking
P.P.S.
My AVCHD test files are available for download if anyone wants to look at them:
http://www.mixtacoda.com/x/avchd/ph-1080-60i.MTS
http://www.mixtacoda.com/x/avchd/ha-1080-60i.MTS
http://www.mixtacoda.com/x/avchd/hg-1080-60i.MTS
http://www.mixtacoda.com/x/avchd/he-1080-60i.MTS
http://www.mixtacoda.com/x/avchd/ph-1080-30P.MTS
http://www.mixtacoda.com/x/avchd/ph-1080-24P.MTS
http://www.mixtacoda.com/x/avchd/ph-720-60p.MTS
http://www.mixtacoda.com/x/avchd/ph-720-30p.MTS
http://www.mixtacoda.com/x/avchd/ph-720-24p.MTS
Old January 5th, 2011, 08:42 AM   #4
I know this is an old thread but I'm having the same issue transcoding AVCHD footage from a Panasonic GF1 which is 30P video in a 59.94 wrapper. The output form NeoScene (v1.6.0) is 2x speed up on the video while audio remains the original speed. I've used the Maintain source frame rate option.
Old January 5th, 2011, 11:23 AM   #5
The 720p/30 format is called "AVCHD Lite" and there is no clear way to detect it. There should be an option to specify this is the source format. On the Mac version there is a check box for AVCHD LIte which will retain the 30fps speed.
Craig Davidson is offline   Reply With Quote
Old January 5th, 2011, 09:35 PM   #6
Ah I'm guessing the version of NeoScene I have doesn't support this feature? can I still upgrade to a version that does offer this feature? I just noticed that you guys were offering free upgrades thru Aug 31st.. Missed out on it!
Old January 18th, 2011, 11:16 PM   #7
I have version 5.2.8 and I can't convert any 720p 60fps clips all the way to completion (stops midway through the clip).
And the video of the portions of the footage that it does manage to convert play back at half speed. Audio, however, is normal speed.
Brad Miller is offline   Reply
