Cineform NeoHD and Flash XDR at DVinfo.net
CineForm Software Showcase
Old January 29th, 2009, 09:43 AM   #1
Images: 10
David...
I took delivery of a Convergent-Design FlashXDR, last week; and, have been doing testing with the device. C-D now has recording working for both .mov and .mxf file types. My testing is principally on a PC, so the .mxf file type is my preference. The mxf record imports into all my NLE's, including Avid Media Composer.
Unfortunately, NeoHD is unable to read these files to do a conversion to CFHD.avi. I've filed a trouble ticket with Cineform for the .mov file format, which also fails to convert. I'm pretty sure Jake is working the .mov issues, but, I thought I'd elevate my problem to you in this forum, as regards the mxf format.
The C-D file records are done with a Sony MPEG2 codec working at 50-100mbps, as I'm sure you are aware.
Thanx for giving this your attention.
Best
Old January 29th, 2009, 02:46 PM   #2
Bill, in general CineForm doesn't support MXF file types. We have made exceptions for specific cameras, but in general MXF won't be supported unless we do work to enable it.
At one time we tested compatibility with some Flash XDR files (don't remember whether they were MOV or AVI) and they were compatible with HD Link, so something must have changed.
David Taylor is offline   Reply With Quote
Old January 29th, 2009, 05:53 PM   #3
Dear David,
If the testing was more than a week or two ago, the tests were probably of our Quicktime, ".mov", files.
We now have our MXF files working in Sony Vegas 8.0(c), Avid, and Edius.
At this time, while our MXF files are still fairly new, we do have confidience in them. They have been reviewed by engineers at Avid and others. Also, since they work well in three different NLE's, we feel that they are likely in conformance with the MXF standard.
We will be happy to supply you with sample files for your testing and development.
Dan Keaton
Augusta Georgia
Old January 31st, 2009, 10:40 AM   #4
We (CineForm) will need a QuickTime file from Flash XDR to investigate why it is incompatible. When we tested a few months the files were compatible, so something might have changed in the biststream. If somebody can either point us to a file on an FTP site, or can email an MOV file to us using a service like YouSendIT to support at cineform dot com, we will take a look at it.
Old January 31st, 2009, 10:45 AM   #5
Dear David,
I will arrange for sample files to be sent to you.
Dan Keaton
Augusta Georgia
Old January 31st, 2009, 10:56 AM   #6
Images: 10
I provided Jake Seagraves, at Cineform tech support, a sample .mov file about a week ago.
Old January 31st, 2009, 11:04 AM   #7
CTO, CineForm Inc.
No harm in extra samples.
Old February 10th, 2009, 09:32 PM   #8
Images: 10
Over 10 days ago I posted this question concerning the ability of Cineform to handle the Sony XDCAM HD codec encoded files from a Convergent_Design FLASH XDR. I've not heard one word concerning the outcome of my question. Is this issue being fixed, or has it been dropped?
Enquiring minds want to know.
Old February 10th, 2009, 10:40 PM   #9
CTO, CineForm Inc.
Follow up with support, I'm not following this project.
Old February 11th, 2009, 09:34 AM   #10
For the many using Premiere CS3/4 and Cineform codec plugins as their NLE workflow, would this allow XDR files to be used once Cineform/C-D sort this out?
This as opposed to going thru the added expense of the Main Concept costs. Know many folks he use the fine Cineform products already.
John Richard is offline   Reply With Quote
Old February 11th, 2009, 09:41 AM   #11
Images: 10
One would hope so.
Old February 12th, 2009, 09:38 PM   #12
Just as follow-up. The original files we tested from Flash XDR last summer were compatible with CineForm conversion software. The latest files we tested were not compatible, so something change in the Convergent file syntax.
We can put this on the list to look at further, but to be honest we have a huge number of tasks on our plate right now so we can't commit to a schedule for this task.
Old May 11th, 2009, 03:22 PM   #13
For those of you still following this subject...
It looks like we'll be able to utilize the components of the latest Sony XDCam viewer software to enable full support for MXF-based Convergent Design Flash XDR source in HDLink.
It doesn't look like we'll have Quicktime support on the PC side, but we'll be testing it on the Mac side shortly.
We hope to have the integration into HDLink by the end of the month!
Step 1 is to download the latest XDCam viewer software (v220) from Sony's site here: https://servicesplus.us.sony.biz/Sof...eDownload.aspx
Tim Bucklin
CineForm Software Engineer
Tim Bucklin is offline   Reply With Quote
Old May 11th, 2009, 03:23 PM   #14
Images: 10
Great News!!!
Thanx, Tim
Old May 21st, 2009, 05:48 PM   #15
Unfortunately we've run into some trouble with this development process, as the Sony components aren't as plug-and-play as initial testing led us to believe.
However, we are working with Sony on the issue of supporting all MXF-based XDCAM formats. So, while support may not come as quickly as we had hoped, we are making progress! It's good to have all three pieces of the puzzle (CineForm, Sony, Convergent Design) working together for a solution.
Tim Bucklin
