Installing cineform with CS4 trial could cause problems? at DVinfo.net
CineForm Software Showcase
Old January 23rd, 2009, 03:50 AM   #1
Hello, I installed Cineform Prospect HD on my computer for CS3 master suite, while i had a trial version of CS4 produciton premium also installed. Is it possible that the Cineform instal was messed up by having some CS4 apps installed and did not properly instal?
I ask because After effects CS3 will not import Cineform files w/o an error but After effects CS4 will import them.
Guess i will try uninstaling the CS4 suite and uninstaling cineform and then reinstaling cineform w only CS3 and see if that fixes it....
Tyson X
Tyson Persall is offline   Reply With Quote
Old January 23rd, 2009, 10:15 AM   #2
CTO, CineForm Inc.
Yes, the installer may have got confused.
Old January 24th, 2009, 02:09 AM   #3
Could not locate adobe premiere plugin registry key.
Uninstalled all CS4 and uninstalled cineform Prospect HD, then i restarted and reinstalled Cineform Prospect HD and i get this message;
Setup was not completed succesfully;
Then i try to uninstal and it says; "Could not locate uninstal.exe."
What should i do now?
Tyson X
Old January 24th, 2009, 10:22 AM   #4
I wish I had a simple answer but I have seen this happen before with CS2 and CS3. It seems that once Adobe installs the latest version it takes over all registry entries and points everything to the latest build. When uninstalling, it seems to remove the pointer to the latest one, but does not restore it to the older version.
In short, uninstalling CS4 removed references from the registry for both CS4 and CS3 that the Cineform installer needs to install. You might have to re-install CS3. I apologize, as I do not remember what I did when this happened to me about 2 years ago.....maybe I did a whole new OS install?
Good Luck.
Marty Hudzik is offline   Reply With Quote
Old January 24th, 2009, 06:17 PM   #5
Do you Think i Should i try Uninstalling CS3 suite and reinstalling it? Would that repair the refrences to "registry entries"
Tyson X
Old January 24th, 2009, 07:07 PM   #6
CTO, CineForm Inc.
CineForm support can send you the missing registty key without uninstalling CS3.
