New betas for the holidays at DVinfo.net
CineForm Software Showcase
Old November 26th, 2008, 06:35 PM   #1
CTO, CineForm Inc.
Many bug fixes so it worth installing if you are not in the middle of a critical project.
Changes include:
Enhanced: the whitebalance accuracy converting Red source to use Active Metadata.
Fixed: a small handle leak in the decoder.
Fixed: Crash in HDLink due to a default stack size too small for some file sources.
Fixed: Very old YUV 8-bit clips where tinted green in half res decodes with Premiere.
Fixed: A memory issue encoding 4:4:4 4K with R2CF.
Fixed: A subtle scaling artifact in large down scales from 4K or above.
Fixed: A crash import some older clips in Premiere that where fine outside Premiere.
NEO HD
http://02bb6aa.netsolhost.com/downlo...187-081126.zip
NEO 4K
Prospect HD
Prospect 4K
Aspect HD
http://02bb6aa.netsolhost.com/downlo...130-081126.zip
NEO HDV was still on the build machine late Wednesday, so it will be out next week.
Old November 26th, 2008, 08:16 PM   #2
CTO, CineForm Inc.
Early reports indicate this build also helps with export issues some were seeing. While we didn't have the issues here, so know bug fix was listed, this memory usage has been tweaked, possibly helping the memory stared Premiere Pro.
Old November 27th, 2008, 06:12 AM   #3
It generates and error for me David when exporting.
Windows XP 64bit CS3
AppName: cfrenderproc.exe AppVer: 1.1.0.4 ModName: cfrenderproc.exe
ModVer: 1.1.0.4 Offset: 00001793
http://www.mlotv.com
Gary Brun is offline   Reply With Quote
Old November 27th, 2008, 07:31 AM   #4
Images: 10
Like the last build, I am unable to transcode directly from the mp4 file in the EX1's BPAV folder. I have to go back to the Sony ClipBrowser to keep HDLINK from crashing. I filed a trouble ticket, but, as of yet, no solution.
Old November 27th, 2008, 10:12 AM   #5
CTO, CineForm Inc.
Gary,
Not seeing export crashes, I download to home PC and all is working fine here as it was at the offfice. CFRenderProc is only use when threading is enabled for exports, while that should be an issue, try turning threading off in the Compiler Settings control panel within the export movie settings.
Old November 27th, 2008, 10:24 AM   #6
CTO, CineForm Inc.
This maybe an external issue, missing or other third components that are interfering, as that is not a known bug as we have many EX using converting MP4s. We will looked into that after the break.
Old November 27th, 2008, 11:09 AM   #7
Images: 10
Thanx. Meantime I have returned to an earlier build which works OK.
Old November 29th, 2008, 12:54 PM   #8
nothing for HDV
Hugh Mobley is offline   Reply With Quote
Old November 29th, 2008, 01:06 PM   #9
CTO, CineForm Inc.
Half the fixes impact HDV users, so it will be a recommended upgrade for everyone.
Old November 30th, 2008, 09:48 AM   #10
AVCHD conversion has no audio???
Using this Prospect beta HDLINK conversions from a Sony SR12 have not audio track in premiere... any ideas?
Deniz Ahmet is offline   Reply With Quote
Old November 30th, 2008, 10:16 AM   #11
CTO, CineForm Inc.
Deniz,
You are likely missing an AC3 Audio decoder. Try installing Free-Codecs.com :: Download AC3 Filter 1.51a : AC3 Filter is a DirectShow filter for AC3 decoding.
Old November 30th, 2008, 12:22 PM   #12
CTO, CineForm Inc.
Think I've found the issue. Please try one these beta links.
P4K http://www.miscdata.com/cineform/P4Kb187.zip
PHD http://www.miscdata.com/cineform/PHDb187.zip
N4K http://www.miscdata.com/cineform/N4Kb187.zip
NHD http://www.miscdata.com/cineform/NHDb187.zip
AHD http://www.miscdata.com/cineform/AHDb130.zip
adding NEO HDV
NHDV http://www.miscdata.com/cineform/NHDVb187.zip
Old December 2nd, 2008, 08:39 AM   #13
b130
Works for me!Latest (5.4) have some problems,crushes with EX1 files conversion..and premiere export was with freezed frames.But latest beta b130 havn't any of these issues.
Nice!
Raul Rooma is offline   Reply With Quote
Old December 2nd, 2008, 08:58 AM   #14
Images: 10
David...
yes, this fixes the problem. Thanx, so much.
Old December 2nd, 2008, 09:45 AM   #15
Images: 10
David...
Question: I re-transcoded an mp4 clip that I had transcoded a few months ago. The same original 16 sec clip transcoded to 463MB before, now it transcodes to 272MB. The "quality" settings were unchanged for each transcode. Bitrates changed from 29.4MBps to 17.2MBps. Am I imagining the same quality now transcodes in half the size and bitrate, or is something really MUCH better in the transcoding algorithms?
Bill Ravens is offline   Reply
