Cineform with Encore CS4 Only at DVinfo.net
CineForm Software Showcase
Old November 24th, 2008, 04:55 PM   #1
Hi all, I realise Cineform is not happening with Premiere CS4 yet - but can I use Cineform with Premiere CS3 and into Encore CS4?
Deniz Ahmet is offline   Reply With Quote
Old November 24th, 2008, 09:36 PM   #2
CTO, CineForm Inc.
If you install all of CS4 after Aspect HD, all will work, you just won't get any CineForm acceleration.
Old November 25th, 2008, 10:06 AM   #3
That's great news. Is there an easy way to correct the mistake if we didn't install things in the correct order? Remove everything and start again?
If it does work, I don't even think I need CS3. I can do without the RT effects for now. No big deal.
Craig Irving is offline   Reply With Quote
Old November 25th, 2008, 10:15 AM   #4
CTO, CineForm Inc.
Yes, you need to remove the CFHD importer (im-CFHD_File_Import.prm) from
C:\Program Files\Adobe\Common\plug-ins\CS4\MediaCore
C:\Program Files\Adobe\Adobe Premiere Pro CS4\Plug-ins\en_US\CineForm
