DPX2CF - difficulty converting files at DVinfo.net
CineForm Software Showcase
Old August 18th, 2008, 03:50 PM   #1
David,
I am attempting to convert 4096x2304 DPX files to CFHDAVI files using DPX2CF on my computer which had Prospect 4K installed.
I have moved the DPX2CF.exe utility from its installed location into my C:\Windows\System32 directory.
From the directory where the my DPX files are located, I type:
dpx2cf s:\red\dpx\Test 1[1].4096x2304\ 014711.dpx s:\output\014711.avi f=24.
to which I get the following:
"'dpx2cf' is not recognized as an internal or external command..."
I'm certain I am engaged in some form of idiocy but any help you could offer would be greatly appreciated.
Also if I am able to get this to convert, how do I batch convert a folder full of DPX files?
Many thanks...
David H. Wilson is offline   Reply With Quote
Old August 18th, 2008, 04:35 PM   #2
CTO, CineForm Inc.
Somehow your execute path is weird.
From a DOS Prompt type
set path
This will show where your system looks for executables (and C:\WINDOWS\system32 should be listed.)
dpx2cf
Alone this should tell you some usage info.
Note: Never have spaces in paths and filename or you will be in for a headache. To deal with spaces in paths you will have to add quotes like this
dpx2cf "s:\red\dpx\Test 1[1].4096x2304\*.dpx" s:\output\Test1[1].avi f=24
the 014711 was replaces with '*', a wild card to convert all the DPXs in that path to a single AVI.
Old August 18th, 2008, 05:48 PM   #3
David,
Many thanks - idiocy on my part as I suspected. Working just fine now.
