Premiere Pro problems at DVinfo.net
CineForm Software Showcase
Old August 5th, 2008, 03:50 PM   #1
Hi everyone:
I made a clean install of windows and adobe suite, Installed Prospect 4K.
Problem is that when I import a CF file to the timeline, a red marker appears on all the clips.
Iīve checked the Global settings, and it shouldnt do that. Uninstalled CF and reinstaled it again and the same thing happens.
Maybe one of you experienced some of this and have a quick workaround.
Sergio Sanchez is offline   Reply With Quote
Old August 5th, 2008, 05:46 PM   #2
Sergio, the first thing to check.... did you select a CineForm preset when launching PPro? If you're not using a CineForm preset the CineForm engine is not loaded, and CineForm clips will appear red on the PPro timeline.
David Taylor is offline   Reply With Quote
Old August 5th, 2008, 08:02 PM   #3
It was some kind of error in the Premiere installation.
Reinstalled everything again and now is working.
One of those things that makes you love windows.
Old August 5th, 2008, 10:20 PM   #4
Sergio, thanks for following up. Frustrating as the problem was to work through, I'm glad it worked out.
Old August 6th, 2008, 02:02 PM   #5
Today a strange thing.
Some clips in the timeline has a red marker over, and others dont. All the clips come from the same source, and they have the same properties. There are no filters applied to any of them.
Do you think itīs a bug in the importer?
Old August 6th, 2008, 03:36 PM   #6
CTO, CineForm Inc.
Check the clips frame rate as even a slight mismatch will cause a Red line.
