Exporting Error with Pr and P4K at DVinfo.net
CineForm Software Showcase
Old July 14th, 2008, 11:20 AM   #1
Prospect 4K 3.3.2 Build 171 and build 169.
I am trying to export a 13 minute 1920 x 1080 project out of Premiere. All clips are CFHD Film Scan 1.
Encoder Controls: High HD Optimized
4:4:4 encoding Enabled
Threadin Enabled
The export to AVI renders a few frames and pops up with the error "Error Compiling Movie. Unknown Error".
Other renders to other codecs work fine.
Chris
Christopher Grant Harvey is offline   Reply With Quote
Old July 14th, 2008, 11:27 AM   #2
CTO, CineForm Inc.
Report to support.
They will need to know when in the export the failure occurs, and whether disabling threading fixes the issue.
Old July 14th, 2008, 11:32 AM   #3
Will do, threading makes no difference and it seems to fail on different frames each time.
I was hoping it was a bug with the new build because I have no idea why this is occuring.
Chris
Old July 14th, 2008, 01:07 PM   #4
Chris, we had the same prob a couple of builds back and switched to HD High output as the optimized seems to give some probs. We've also switched off the threading. After those changes, everything seems to be okay.
It almost seems like another memory ceiling that Premiere is coming up against. Are you using XP x64 or 32bit?
http://lightinaction.org
"All in the view of the LION"
Stephen Armour is offline   Reply With Quote
Old July 14th, 2008, 01:13 PM   #5
Thanks for your response Stephen. I figured it was some memory issue.
I'm running XP 32bit 4GB RAM with 3GB Switch.
Old July 14th, 2008, 03:26 PM   #6
Update: Under PPRO's preferances I set the priority to Memory and not Performance.
Exporting at High HD with no 444 and no threading, so far render is 2 hours and 3 minutes in and is at 57.91% on my Quad core... jeez.
But it has not bombed out yet.
Old July 15th, 2008, 10:46 AM   #7
More update.
The render I posted about last night failed and 2 renders post that failed too.
I finally managed to export my HD out and it took an amazingly slow 8 hours. I have never had probems like this before exporting even Film Scan2 4:4:4 out of PPRO...
