Frame blend and aspect HD at DVinfo.net
CineForm Software Showcase
Old July 4th, 2008, 05:11 AM   #1
In premiere when you convert a footage into slowmotion (60% blayback for example)
frame blend will be automaticly be applied!
My question is: does aspect HD also output the frame blend in the final result?
Because it doesnt seem to work in the preview window? I see a red cross in my preview window over my image!
Rob Willemse is offline   Reply With Quote
Old July 4th, 2008, 09:39 AM   #2
CTO, CineForm Inc.
That is why there is a red bar, we can't play the frame blending in real-time. Render it or export it and the frame blending will be present, unless you choose to turn it off.
Old December 3rd, 2008, 08:07 PM   #3
can you turn it off and then on final export turn it on.
in other words, edit with frame blend off (it could be hundereds of clips) and the flick a swith before export and frame blend will be on (albeit with render needed)>
Frank Vrionis is offline   Reply With Quote
Old December 6th, 2008, 07:34 AM   #4
didn't think so
